I have a Giant dropper post on my Reign which to be fair has been a great dropper.My only concern is how the cable is ran with it just coming down behind the seat post and rubbing on the top of the suspension arm to the stage it has caused a bit of bad cable rub.I know you can buy the Hope seat clamps with a plastic bit to hold cable.but I feel it will still sit against the suspension
Has anyone had a better solution to routing the cable to keep it out of the way.i don't run a front me h any longer and wondered if i could use the cable boss running down the seat stay to keep it in place
Cheers for any input
Tape?
Done the tape but the friction must be bad to wear through the tape,the foam things from Decathlon might be a better idea
2 cable ties. One tight around the seatpost holding the other as a small loop with dropper cable going through it
