Drop bar position a...
[Closed] Drop bar position and shape
28 Users
Offline  lunge
Share this post
I don't think you're far off. I'd move the hoods up a touch, not much, and you're about there.
Posted : 12/01/2021 6:02 pm
Offline  matt_outandabout
Share this post
That's what I've settled on @lunge - bars as is, shifter nudged up a touch.
Posted : 12/01/2021 6:24 pm
Online  chakaping
Share this post
Give it a go, but you may prefer a bar that has the same shape at the top but curves round closer to flat (or even slightly upward) at the end.
I certainly like that kind of shape, so I've got something to push against when honking out of the saddle.
Posted : 12/01/2021 6:35 pm
Offline  forked
Share this post
Matt,
The bottom section of your bars should be parallel to the floor (or as near as dammit).
How tall are you? I'd wager your bars are too high, and your saddle is too high - this is a combination that'll force you in to an upright position. Lower both, and try and stretch out more.
Posted : 12/01/2021 8:21 pm
Offline  molgrips
Share this post
I don't think this is true. Modern bars come in such a variety of shapes this would really curtail your fit options if it's even possible.
I tweaked the bars on my new bike and the position I ended up with is pretty much the same as how it is in this pic, maybe rotated forwards a smidge:
Posted : 12/01/2021 11:21 pm
Remove ads
Offline  scotroutes
Share this post
The 90's called and want their bike-fit back.
Posted : 12/01/2021 11:41 pm
Offline  cynic-al
Share this post
The 90’s called and want their bike-fit back
Out of order. In the 90s we actually looked at the rider on his bike before advising.
Posted : 12/01/2021 11:44 pm
Offline  joeegg
Share this post
I have the same problem with reach to the levers. From experience a short reach and drop works best for me. I set my bars with an imaginary ball bearing in the open end that would slowly roll out. So,not parallel to the ground. Then hoods which would give as smooth a transition as possible from top of bar to top of hood.
Posted : 13/01/2021 12:06 am
Share this post
So slightly worse than I had to start with?
I've only done one short ride so far. It feels a longer reach, however the drops and reach to levers is much better, my wrists also felt less 'pulled'.
Posted : 13/01/2021 8:53 am
Offline  kingofhtefr
Share this post
Posted : 28/02/2021 12:21 am
Remove ads
Offline  cynic-al
Share this post
1. "ground" no need to thank me 🙂
2. I set mine with a bit of a tilt, perfectly flat means my wrist is bent uncomfortably on the flat section. But they aren't compacts.
3. Not sure I would say everyone should have their bars set up a specific way, you can then get into stuff like KOPS which I don't agree with.
Posted : 28/02/2021 1:05 am
Share this post
An update.
The bars are better rolled up more and levers further around. I prefer them.
I am still not convinced that I have the 'right' shape of bar for me / my wrists. It is princess and pea stuff still - it feels that when I ride on the hoods it is a good pull forward. it feels a touch 'odd' to be in the drops, it pulls my arms in (too narrow? no flare?) and means the reach to the brake constantly feels a stretch in my hand.
Please recommend some other bars to try - I ride 80% road, less reach would still be good. Cheap too as I cannot spend dafty money trying out ideas.
Posted : 19/03/2021 1:21 pm
Page 2 / 2
