Drilling out a torq...
[Closed] Drilling out a torq screw head.
[#3308771]
As above , I managed to snap the end of a torq screwdriver head in my Juicy front caliper. Whats the easiest way to get It out without knackering the whole caliper head. ?
Posted : 02/11/2011 4:41 pm
If the tip of the torx screwdriver bit is stuck in the bolt I'd focus on trying to get that out, maybe pry it out with a small screwdriver. If that fails the dremmil a slot and use a flat bladed screwdriver. Depends on the postion but you might get a pair of molgrips around the bolt but you need some space and risk scratching the surface.
Posted : 02/11/2011 5:12 pm
Is it the bleed port bolt?
Araldite a bit to it and leave it to dry then remove it once it's dried and replace the bleed bolt.
Posted : 02/11/2011 5:25 pm
Too late for Araldite , Now look like they have been with an RPG. 🙄 . Just bought some of the Classifieds. 😀
Posted : 02/11/2011 8:49 pm
Have you tried using 'easy outs?
I snapped a torx bit in my rear mech hanger and that got it out after I'd nearly destroyed my rear triangle
Posted : 02/11/2011 9:07 pm
Ill check them out mate.
Posted : 02/11/2011 9:49 pm
It the broken off bit from the driver jammed in the head of the screw ?
Posted : 02/11/2011 9:54 pm
it's hard to drill out a pan head torx screw by hand accurately if the head is totally snapped off as centring your drill bit can be tricky, might be worth getting it done on a pillar drill, even small EZ outs need about a 3.5 to 4mm hole which doesn't leave much margin for error on an M5 bolt.
Posted : 02/11/2011 11:28 pm
