Drill or mill cable...
[Closed] Drill or mill cable guides
[#1766490]
Want to run full length outers - better to drill out or mill off the ends of the guides - erring on the side of milling as it seems less accident prone
Posted : 04/07/2010 10:00 am
Small engineers file.
Posted : 04/07/2010 10:11 am
will take days!!
Posted : 04/07/2010 10:13 am
I've drilled them on several frames but you normally need a long series drill.
Clamping the frame for milling would be awkward and possibly more likely to cause more damage than opening up the guides
Posted : 04/07/2010 10:16 am
You must have a pretty impressive milling machine to clamp a frame in it!
Posted : 04/07/2010 10:17 am
Milling runs the risk of damage when you clamp the frame and will always be visible. How about using a Dremel, you get the speed with a similar result as drilling or filing.
Posted : 04/07/2010 10:18 am
will take days!!
If you're a softhanded office worker maybe. 😉
Posted : 04/07/2010 10:21 am
I use these on the Airborne
[url] http://www.swinnertoncycles.co.uk/M-Part-Top-Tube-Disc-Cable-Guide-Set.aspx [/url]
Posted : 04/07/2010 10:29 am
 Del
^ needlefile and a pot of MTFU. 😀
Posted : 04/07/2010 1:51 pm
File works fine for me but otherwise drill it out to just fit shimano gear outer and it'll still work with split outer routing if you want to revert.
Posted : 04/07/2010 2:00 pm
