Dream bike thread
[Closed] Dream bike thread
[#7277592]
Right, as far as I can tell this hasn't been done before so I'll start.
Frame: Yeti SB5c
forks: BOS Deville
wheels: ENVE M60 40s on hope pro 2 hubs
Transmission: XTR stuff
Finishing kit: whatevers carbon and looks cool
Post your dream bike/ Build 🙂
Posted : 19/08/2015 10:17 pm
 ton
sofa comfy touring bike. internal wide range gearing. low maintenance brakes.
Posted : 19/08/2015 10:22 pm
One with really glittery, holographic chip paint.
Posted : 19/08/2015 10:24 pm
Donhou DSS1. I just do. Don't ask me to justify it.
Posted : 19/08/2015 10:26 pm
This is a very subjective thread, I've had the pleasure of riding a couple of dream build, XTR-everything bikes, but sometimes the hassle factor of say, snapping a spoke in an exotic wheelset makes the day to day reality of a superbike a pain.
If money and spousal understanding were truly no object, then I'd be looking at an Ibis Mojo complete with nu-skool Lyriks or DVO forks, XTR drivetrain and carbon rims. The stopping duties would be taken care of by Hope, along with the finishing kit, cranks etc.
But it would all be on the proviso that the geometry would be perfect, the suspension sublime and the bottom bracket something sensible - i.e. with threads.
Posted : 19/08/2015 10:42 pm
Dream bike ?
Id be happy swapping my G150 for a 2016 G160 works ....
Posted : 19/08/2015 10:52 pm
Pivot Les Fat.
Couple of sets of wheels, fat & 29+.
Thomson finishing kit.
Set up singlespeed.
Needs to be all black.
Posted : 19/08/2015 10:55 pm
Antidote CarbonJack with a DVO Diamond and a Float X2, fitted with Sram XX1, Magura MT7 brakes, Spank Oozy wheelsRace Face finishing kit with SixC cranks.
Posted : 19/08/2015 11:00 pm
My dream bike? Ive already got it 😉
Posted : 19/08/2015 11:07 pm
I am fortunate to have both of mine, santa cruz nomad cc and production privee shan. Shan only needs 11sp and it would be perfect
Posted : 19/08/2015 11:16 pm
Mondraker Carbon Dune with Bos Kirk + Deville, Enve wheels and finishing kit, Sram XX1 & Hope Brakes.
I shudder thinking how much that would be 😯
Posted : 19/08/2015 11:32 pm
A ti version of my Solaris, some really s****y wheels, 1x something gearing, that Bluetooth Thompson dropper when it comes out and carbon kit to finish. That'll do me.
If we're going for full suss carbon wonderbikes I'd happily take a pivot 429 trail with trimmings.
Posted : 19/08/2015 11:40 pm
That's a very predictable marketing led dream.
Posted : 19/08/2015 11:47 pm
Carbon Remedy 29 and throw expensives at it. I don't think it's right to be dreaming about a Trek, mind.
Posted : 19/08/2015 11:55 pm
Nicolai Helius. XTR, Custom brakes for a big bloke, likewise nice wheels that can cope with Alps or everyday use here in very wet Wales- DT Swiss win. Sapim spokes. Good wide bars. Stem- take your pick, loads of excellent choices, just go for a 4 bolt faceplate. Pedals- again, very personal but Time for me. Grips? Depending on intended use there are loads to chose from. FWIW the silicon grips I used in the heat in Les Gets/ Morzine last week softened so much I might as well have had them removed and just used the bare bars.
Posted : 19/08/2015 11:56 pm
Nobody's said hand-made yet.
I'd like a nice light carbon HT made to fit my little legs.
APF
Posted : 20/08/2015 12:00 am
I'd happily swap my ENVE XC rims for newer ENVE rims be easier to tubeless I guess
Posted : 20/08/2015 12:07 am
Cotic Rocket 29er in that SLS blue
with 33 speed XTR and brakes
150mm Pikes
Carbon rims
One that, literally, flies.
To all those wanting enves, are you sure? They are a royal pita. Want to true a wheel? Tyre and rim strip has to come off. Everyone thinks you are a **** when they see you with them, for whatever reason. While the warranty/crash replacement is good, they are silly money so you almost have to break one to get your money's worth. Stiffness is not the be all and end all when it comes to rims.
I speak as an owner of 2 pairs (bought close together). Id have to have a pretty compelling reason to buy them again.
Dirty rider. They aren't. Lbs had 4 goes at sorting my front after it burped. I have a tube in there at the moment.
Posted : 20/08/2015 12:14 am
SB66c with Pikes & Enve everywhere else.
Posted : 20/08/2015 12:47 am
handmade steel frame
in ride adjustable geometery from XC to gnar
fat+ front tyre
1x11 saint di2 rear mech on an 11-44 casette
oval NW chainring
super stiff, super light coil forks, that go from 100 to 160mm
climbs like an xc bike, goes like a cx bikeon the flat and descends like a DH bike.
weighs not much.
you said dream right?
Posted : 20/08/2015 1:19 am
When I "retire" to social biking only my stock will be consolidated as follows:
MTB = Turner Burner
Road = An Enigma fast endurance geo
Posted : 20/08/2015 1:26 am
12.5kg Full suspension Carbon frame
Mixed XTR and XX1 group-set
Carbon rims and accessories
Cane Creek shock, Fox 36 up front
....wait, that is my existing bike 🙂
I fancy a full suspension all mountain trike.
Posted : 20/08/2015 1:34 am
I'm (really) incredibly close. This is what I've got:
Chromag Samurai65.
In my ideal world:
- upgrade hubs to Chris King, maybe.
- upgrade XT to XTR, maybe.
- upgrade fork to 350NCR Titanium, maybe.
- upgrade cranks to RaceFace carbon, maybe.
- add Schwalbe Procore.
- have a custom respray (including fork legs) each Spring.
- have a mechanic pop round every month or so to change the cables, bleed the brakes, replace the pads and tyres and do a fork service.
The things that stop it being dreamy all the time are (i) nagging mechanical issues caused by laziness, and (ii) lack of inspiration to ride.
EDIT: It has a black Spurcycle bell now, which is pretty much the icing on the cake. 😉
Posted : 20/08/2015 3:22 am
Yes if we are talking dream bike then a custom made carbon hardtail would do the trick, xc race light but with a nod towards 'trail' geo, h.a. Around 68 and designed for a short but not crazy (say 65mm) stem to give me perfect reach ans stability but with less front wheel wander than I have at present and designed around 120mm forks. Get some of those bos dizzy forks, 1 by 11 gearing, lightweight components, maybe an internally routed ks lev ci dropper
Posted : 20/08/2015 6:31 am
Oh man that samurai is gorgeous! Did you ship it over from Canada or buy it here?
Posted : 20/08/2015 7:50 am
Mines probably the YT Capra Pro, it would compliment my 'garage' too with my XC rigid Carbon bike, heavily upgraded Whyte 901 and that.
Posted : 20/08/2015 8:06 am
Custom for me. Maybe something from 44 for the MTB and then a roadie from Field. Oh and a top spec cannondale slate; no idea why but I want one.
Posted : 20/08/2015 8:25 am
Evil Following (or Carbon Transition Smuggler, if it existed) with some XTR Di2, XTR brakes and pedals, Pikes, Enve wheels on King hubs, Reverb, Easton bar & stem and RF Next SL cranks...
Posted : 20/08/2015 8:30 am
That Chromag is very nice 🙂
Posted : 20/08/2015 8:48 am
My dreams keep changing...
This is going to be the current dream bike:
Posted : 20/08/2015 8:55 am
Steel HT built by myself.
Made to take 100 mm forks, but I would have some ridgids made too, if possible make it able to take 120mm fork but not centered around this.
About the length of my 19.5" inbred but lower top tube (make it like a large BMX).
Good tyre clearence for 2.5" tyre with load of mud, 2.85" at a squeeze. Pannier mount should there be the need. Slot dropouts for SS compatability.
Two sets of wheels, one super strong one light weight. Stong rear wheel would have hope SS trails hub with howevermany cogs would fit.
Extra front wheel with dynohub.
Custom racks for when the need arises.
Selection of bars an stems depending on what I am riding.
Not bothered about the rest. TBH.
Posted : 20/08/2015 9:04 am
You know, what with all the ridiculous standards of MTB wheels, frame materials and shit, I had absolutely no idea what my dream bike would be when I finally got the dosh together to buy it. So I decided my 575 was perfectly adequate in a "it's fab" kind of way.
And went for a dream CX instead. Frame arrives tomorrow and parts are gathering around the house.
Ksyrium Pro wheelsm, Dura Ace cranks, plus this little lot
Pics will appear on the ... Tripster thread next week, no doubt. 🙂
Posted : 20/08/2015 9:23 am
Dream bike... probably what I've got or what I can buy off the shelf... But with a stealth electric assist and not weighing any more.
Posted : 20/08/2015 9:28 am
New Turner RFX, with a set of those new Alchemist Carbon rims on DT240s, Fox36 up front, maybe that new Float X2 with the climb switch out back, Enve bars, Syntace megaforce stem, Lev Integra 150 dropper, Next SL cranks, XTR 11 speed with XX1 cassette, Vault MG pedals with Ti axles, Hope E4 Race brakes. Not that I've given it much thought.
Posted : 20/08/2015 9:36 am
ASR 5 29c (doesn't exist, I know) for most stuff
and a
custom nicolai ion for Braaarrrp
Cotic soda/solaris 29 ti for being a racist on
Something aero and carbon for the road
a custom steel cxer for plodding about/winter/commuting
Unless anyone here wants to buy my children these will have to remain in the dream realm
Posted : 20/08/2015 9:44 am
As I find it difficult to dream so big that even if I had my dream bike I would still have to keep it for a long time and do the fettling myself.
A custom Built Carbon Fibre Orange Five copy for 26" Wheels, a tad longer and a tad shorter in the seattube than my current 18" two sets of Pikes at 160mm ( the spare as 26" may not be around long and a I am a bit breaky ) 1x11 xtr. Not bothered about the wheels so much so two sets of Hopes with carbon rims would do me fine :), One set with a Rolhoff. Finishing kit all carbon with a reverb dropper.
also a 853 hardtail that I had built myself.
I'm lucky to have mine, Cant thing of anything I would change, upgrade or tempt me away from it
Posted : 20/08/2015 10:35 am
