My Enduro SL has 2 or 3 plastic clips that are fixed by an allen bolt under the downtube. They have 2 indents one side and one on the other, to carry 3 cables.
Does anyone know of a retrofit part that has 2 indents either side for 4 cables/hoses?
Can I ask why......
....do you have 4 cables?
at a guess... front mech, rear mech, reverb, brake
could you just zip tie the seat post hose to the brake one?
I could just zip tie it, but would be neater if it had a proper clip for it.
I'm running a KS i950 and will shortly be adding the remote
[url= http://www.shapeways.com/shops/ODCtechnologies ]Available here[/url]
Cheers hg - the 1st ones might work, as there is some distance from the hole to the cable retainer. The ones in the link would sit too close to the existing clip though
Loads of those P clips available on ebay. Picked up 10 for £1.50 or something. Using them for cable guides on my Kona.
almightydutch has it - cheers very muchly!
