Downhill forks vs t...
[Closed] Downhill forks vs trail forks for plushness?
[#2161880]
Hey guys, a wee question, i have a Patriot, thinking of putting 180mm Boxxers to do a bit of downhilling. How much difference would this make to the handling? I,m running Fox Van 36,s 160mm. Are downhill forks plusher? Would they give a much softer ride?
Obviously i know they are heavier, stiffer stronger etc.
Thanks
Posted : 05/11/2010 10:45 pm
Best get a test bike with these forks on and give it a go
Posted : 05/11/2010 10:53 pm
 GW
there's no such thing as a 180mm Boxxer.
would you ike to be more specific?
year? model?
plusher = WTF?
softer ride?
fit a softer spring to your 36 if you want a softer fork
Posted : 05/11/2010 10:55 pm
 GW
oh.. and don't worry about the bike, it's perfectly upto the job, just go downhilling!
Posted : 05/11/2010 10:57 pm
Aye there is/was.
Posted : 05/11/2010 10:58 pm
You are far better off keeping it as it is and if you want a proper dh bike, buy a proper dh bike. If you want more comfort fit a 2.5" DH front tyre and run it soft. Vans are a good fork.
Posted : 05/11/2010 10:59 pm
I'd agree, 36s are well suited to that bike. Triple clamps would probably annoy you more than they helped.
Posted : 05/11/2010 11:12 pm
 GW
when, Brycey?
Boxxer 151 - 151mm
2000-04 Boxxer 176mm
Boxxer ride 133-178mm
05 -2010 Boxxer 203mm
2010+ Boxxer 203mm
my memory fails me 😕
keep single crowns, sounds like you need something to spend cash on, id suggest not
Posted : 05/11/2010 11:13 pm
Catch a grip GW.
Posted : 05/11/2010 11:16 pm
I wouldn't bother getting boxxers on it tbh, although the old cherry red (2000-04) boxxers were amazing! You'd be doing well to find a decade old pair of dh forks that aren't totally ****ed...
Posted : 05/11/2010 11:22 pm
Hey guys, cheers for the advice, yea was just a thought i had, cos i know Patriot ST,s came with 180mm forks and were a down hill bike. Cant really afford a true down hill bike.
But i,m going to take everyones advice, keep the vans and maybe save up for a 224 😉
Posted : 06/11/2010 2:17 am
 st
yYep, stick as you are. by all means put Boxxers on the Patriot to turn it into a DH bike but then forget using it for let else.
Posted : 06/11/2010 8:21 am
 jonk
I run a 180mm domain on my patriot for downhill duties and its really quite good.
Posted : 06/11/2010 9:26 am
You can get Boxxers custom made by TF to run at 180mm.
On the original point, there is a difference between a fork being 'plush' and a fork that allows you to ride faster. Comfort and grip aren't always synonymous.
Posted : 06/11/2010 10:02 am
Plushness = custom damping?
Posted : 06/11/2010 11:15 am
