Double-sided pedals...
[Closed] Double-sided pedals for CX/commuter
[#8181203]
Commuting is across Central London, CXing is around local bridleways.
I want something that doesn't start creaking after a week. Any recommendations?
I'm currently using some low/mid-range Shimano xc pedals (no cage) but the cleats creak like hell and I really don't trust them (I have pulled out several times, despite adjusting the tension accordingly).
Posted : 26/11/2016 11:13 pm
Your either using multi release or very worn cleats.
Shimano xt touring here on my all round bike
Posted : 26/11/2016 11:16 pm
XT Touring (Shimano model T780).
They're without equal in my opinion.
Posted : 26/11/2016 11:29 pm
Thanks but I want double-sided.
Posted : 26/11/2016 11:35 pm
Shimano pd m580. Cheap, good.
Posted : 27/11/2016 9:04 am
I have the Shimano A530 - the flat side is ok in trainers/soft shoes, but a bit slippy in 'normal' shoes.
Posted : 27/11/2016 9:14 am
HT Components are bringing out a new double pedal, think it's called the D1.
It might be a rather heavy duty option for what you plan to use them for though..
Posted : 27/11/2016 9:52 am
What do you mean by 'double sided'? You mean just conventional SPD pedals with SPD jaws on either side or something else? Alpkit / Sonder has a pedal that's SPD one side and flat with pins on the other. But even low-end Shimano should do the job - maybe try different cleats. Not the multi-entry ones.
Posted : 27/11/2016 10:16 am
I'm also not sure what you mean by double sided
I like the look of the funn mamba pedal for platform one side clip the other
http://www.chainreactioncycles.com/funn-mamba-one-side-clip-mtb-pedals/rp-prod122715
Although haven't used them myself
Posted : 27/11/2016 10:27 am
I have the Shinano M324 ones and like jimdubleyou, find the flat side a bit dicey on occasions with leather-soled shoes. If the Shimano PD-T420 had been available and, I'd have probably gone for those.
Posted : 27/11/2016 10:46 am
So you want normal SPD pedals then
Shimano xt SPD's then -can be had nice and cheap. Change your cleats
Posted : 27/11/2016 11:48 am
2nd changing your cleats. Make sure you buy single realise if you like a secure foot.
Posted : 27/11/2016 12:01 pm
