Double front mech
[Closed] Double front mech
[#4097449]
Hi
I'm running a 22/36 ring set up. Does anyone know if an xt double front mech will work with this big a jump between the rings? It's the E type one I need for my zesty, and it says 12T max, but wondered if this was really the case??
Posted : 24/06/2012 2:32 am
I use a 3x9 XT E-type with my SLX 36/22 with no problems at all on my 2011 Yeti 575, works perfect. Just had to screw in the top stop screw to compensate for lack of big ring
Posted : 24/06/2012 2:51 am
You will be fine.
E-type will only work properly with a 32-44 middle-large though.
The mech's height is fixed by the bracket and will properly shift from 32 up to a 44. If you have a 34 and a large ring that is not 44 you will be in trouble.
PaulD
Posted : 24/06/2012 11:33 am
