Domains vs Sektors?
[Closed] Domains vs Sektors?
[#6962036]
Out of the 2 which would be better?
I currently have a set of Domains 150mm on my bike but have been told about a set of Sektors 'sitting there' and would be possibly up for a swap. Both are tapered, both 20mm axle and both are 150mm.
If the Sektors are good (when i get to see them) should i swap or should i stick to the Domains? Normally ride Brechfa and Nant yr Arian.
Thanks.
Posted : 27/03/2015 7:22 pm
Sektors are cheaper revs, 32mm stanchions. Domains are cheap Lyriks, 35mm steel stanchions. You'll loose some stiffness withe the sektors but you'll also loose a ton of weight. Are the Domains 302s or 318s? and what spring/damper are the sektors?
Posted : 27/03/2015 7:30 pm
Pretty different forks tbh! If you're doing riding that justifies the strength and the pork of the domains, maybe stick with those.
And yah, internals more important than names, the basic domains and sektors are rotten but the ranges cover a lot of ground
Posted : 27/03/2015 8:01 pm
