Domains upgrade or ...
Domains upgrade or not
[#12719493]
So I picked up a cheap set of Domains to try my eeb out in Mullet flavour and I’m enjoying it
my quandary is,do I sell them and try get Zebs ultimates or keep them and upgrade damper which would be less of a ballache with having to advertise,Be inundated with spam and eidjits offering 50p and a beano kinda lowball offerings
Posted : 10/02/2023 4:51 pm
the novyparts splug is a decent moco upgrade if you do go for the damper. probably cheaper than a fork swap.
if not i`ll have the domains for 50p and a beano
Posted : 10/02/2023 4:57 pm
What’s wrong with the current damper? I have Zeb ultimates on the full suss and domains on the hardtail. Both get a hard life. The biggest difference is weight. I don’t mind the domains at all in stock form, the damping isn’t amazing but I haven’t felt the need to upgrade. I’d run the domains until the damper needs a service and then upgrade the damper if you fancy it. Weight isn’t an issue on an eeb so I wouldn’t bother swapping for zebs personally.
Posted : 10/02/2023 9:40 pm
Nowt really wrong with the damper apart from it being old tech
All newer Rockshox are using charger damper
Domains are using Motion control
Posted : 15/02/2023 6:23 pm
