Does this look OK t...
[Closed] Does this look OK to you?
[#6058014]
Friend purchased this used carbon 456 frame. The seatpost seems a little slack when inserted, (yes, we have the right size...), and the clamp seems to need a lot of tightening - does the clamp area look OK to you?
Cheers.
[URL= http://i1252.photobucket.com/albums/hh567/Blisterman1962/DSC_0098_zpsc3e87b1e.jp g" target="_blank">http://i1252.photobucket.com/albums/hh567/Blisterman1962/DSC_0098_zpsc3e87b1e.jp g"/> [/IMG][/URL]
[URL= http://i1252.photobucket.com/albums/hh567/Blisterman1962/DSC_0097_zpsca027ea4.jp g" target="_blank">http://i1252.photobucket.com/albums/hh567/Blisterman1962/DSC_0097_zpsca027ea4.jp g"/> [/IMG][/URL]
Posted : 23/03/2014 8:32 am
Not familiar with that particular frame but it looks like a crack in the top pic unless that's a really badly finished mold line.
Posted : 23/03/2014 8:34 am
Have you tried using carbon assembly paste? Looks more like a mold line down the top tube to me.
A
Posted : 23/03/2014 9:12 am
Looks like standard no frills Chinese carbon frame finish to me (my road frame is similar)
Posted : 23/03/2014 9:23 am
your tyre's on the wrong way round )
Posted : 23/03/2014 9:41 am
Top notch grouting
Posted : 23/03/2014 9:44 am
Has someone nicked your chain?
That does look rough. Is that normal on plastic frames?
*No idea, never had a plastic frame. So I'm of no use and just wasting your time. You can thank me later. 😉
Posted : 23/03/2014 10:02 am
I've got an On-One Lurcher and have a coke can shim between outside of seatpost tube and inside of clamp. Lots of carbon paste, too.
Posted : 23/03/2014 10:18 am
Thanks all, some useful comments, and some not so useful. 😉
No cracks in the area, just a bit ropey. No chain, as bike mid-build. Not responsible for my friends tyre orientation, but he will be advised he could die.
Grouting?
I think the coke can shim and paste are probably most useful, thanks.
Posted : 23/03/2014 2:03 pm
 Olly
Tyre looks correct to me. square blocks have the edges on the leading edge, ramps to the rear
Posted : 23/03/2014 2:28 pm
My old 456 was the same as that ruff as F#### also seat post was sloppy think there made cheap.
Posted : 23/03/2014 2:29 pm
Top notch grouting
Tile = Grouting
Bricks = Pointing
Everyday's a school-day kids 😉
I'd try a coke can shim, seatpost even when using the correct size can vary. I have various different size posts on various bikes and not one measures the actual size stated, got 3 x 27.2 posts also 2 alloy ones and a carbon one and when measured with digital calipers they all vary.
Posted : 23/03/2014 3:22 pm
 gogg
When did you last calibrate your calipers?
Posted : 23/03/2014 3:28 pm
2nd Carbon assembly paste to add some bite.
Posted : 23/03/2014 3:32 pm
Previous owner was probably a serial post dropper.
Posted : 23/03/2014 4:16 pm
Latice needs staining.
Posted : 23/03/2014 4:21 pm
Olly - Member
Which would be fine if that was the bottom of the bike or is that the new maxxis airbrake?
Posted : 23/03/2014 5:29 pm
 D0NK
C456? Look's like a it's seen a lot of action, as someone said serial dropper, looks like laminate on outside has gone and maybe a bunch of wear inside too. Carbon paste if your mate doesn't drop his saddle, if he does and wants the frame to last a dropper post is a good shout.
Posted : 23/03/2014 5:55 pm
 D0NK
set up for drive instead of max braking, don't use HR myself but do run some tyres "backwards" like that.
Posted : 23/03/2014 5:58 pm
Frame looks like it has seen plenty of action with lots of scoring inside seat tube, indicative of lots of adjustment and a lack of carbon paste.
Posted : 23/03/2014 9:01 pm
Why not just put something on that isn't ramped?
Posted : 23/03/2014 9:04 pm
I would never settle for a bit of coke can under my seat clamp.
Posted : 23/03/2014 9:08 pm
