does this happen to...
[Closed] does this happen to anyone else
[#3258817]
you're cold. you need to nip to the loo. you have a number 1....and your body gets colder in a directly proportional amount to the length of time you are piddling.
Assuming this doesn't just happen to me (i bloody hope!) why does this happen?
Cheers STW massif
Posted : 19/10/2011 3:41 pm
You are wondering why you get colder when you expose more skin to cold air?
Sorry cant help with that one.
Posted : 19/10/2011 3:55 pm
you have a load of hot liquid inside you... you get rid of the hot liquid... you now have less heat. QED.
Posted : 19/10/2011 3:59 pm
even indoor with central heating!
Alfabus - good point well made
Posted : 19/10/2011 4:01 pm
Do you have an outside loo or does your radiator need bleeding?
Posted : 19/10/2011 4:07 pm
Isn't it at around body temperature, so it's pretty much neutral in terms of heat loss/gain? I would imagine hot pee could be pretty painful.
Posted : 19/10/2011 4:14 pm
neither - just observing that when I pee when I'm cold, the act of peeing makes me colder....and checking I wasn't a freak / in need of medical attention 😳
Posted : 19/10/2011 4:15 pm
Well unless the air in your house is close to body temperature there will still be heat loss when exposing more skin.
Posted : 19/10/2011 4:24 pm
Your blood pressure may drop if you sit stand up quickly, plus sprinting up the stairs will likely send blood to your muscles and not the extremities
Posted : 19/10/2011 4:26 pm
Plus it's worse if you have a big willy. 😳
Posted : 19/10/2011 4:31 pm
Your blood pressure can also drop as a result of quickly emptying a full bladder, which will make you feel cold. Or cause you to pass out.
That used to happen to my mate.
RIP Stanley 🙁
Posted : 19/10/2011 4:38 pm
*bows head in respect of Stanley*
Posted : 19/10/2011 5:24 pm
