Slightly bizarre question I know.
Running a Revelation lock out lever on LH side of bars which I very rarely use.
Getting a Reverb which has a LH lever - can both by run side by side?
If not I might ditch the Revelation remote as the Reverb will be used loads more.
Any suggestions folks?
No reason I can think of if you have the space on the bar. If you only have 1x10/11 then should be fine, might be a bit cuttered if you have a front mech. You could always run the Reverb upside down on the RH - mine is an upside down RH on the LH side.
This has some more info.
http://www.pinkbike.com/news/rockshox-reverb-review-2011.html
Ditch the rev lockout lever. A lockout has no place on a fork.
I have fork lock out and reverb remote on same side (left hand side, 1x10 so no front shifter lever). If there was a cheap and easy way to ditch the fork lock out remote id hve ditched it, mainly because i rarely use it and cant see any benefits from having a remote lockout. Both fit well and easy enough to reach on the bars though. Reverb remote closest to the grip as that gets used a lot more often
Flip the reverb lever and mount it underneath on the right had side. Better protected as well.
