Does anyone on here...
[Closed] Does anyone on here use 3M VHB tape
[#5222242]
Good morning all.
Does anyone here have any experience of 3M double sided adhesive tape? I need to stick a small plastic mount to a piece of aluminium, and this seems like a nice way to do it if it's as sticky as they say - can it really replace spot-welding?
Would anyone have a one-inch length of the stuff I could 'borrow' to try before I commit to a roll of the stuff?
Ta.
Posted : 06/06/2013 9:04 am
Have you contacted 3M I'm sure they will send you a 'sample'
Posted : 06/06/2013 9:13 am
Already on it, but I'm in a hurry and would also like some real-world feedback as this stuff makes wonderful claims that could be snake-oil.
Posted : 06/06/2013 9:24 am
[url=
pretty good...[/url]
It's very good. I use it regularly to hold down parts for machining on the mill. Sticks like the proverbial!
As per the video, prep and burnishing are paramount.
Posted : 06/06/2013 10:13 am
neilneilorangepeel - which tape do you use? I've trawled the 3M site, looks like 5952F is the stuff I need - low energy plastic-to-painted-metals. The specs looks ideal, but I need to beg an inch or so to try before I buy a few rolls...
Posted : 06/06/2013 10:29 am
I've got some 4952 in 19mm wide you can try, slightly higher adhesive strength than 5952 but very similar. Viking tapes are very good at helping source samples, from recollection they can source a 19mm x 3m sample foc.
Posted : 06/06/2013 11:01 am
I'll try Viking now, thanks. If no luck, could I 'borrow' and inch of 4952?
Posted : 06/06/2013 11:52 am
 LS
I use it at work in the lab to stick glass culture flasks to shaking incubator platforms - Although very strong it also allows the flasks to be removed and stays sticky for constant re-use. It stays on the platform for about 6 months before we change it.
Posted : 06/06/2013 12:06 pm
I have quite a few things stuck to other things with VHB - it's really good stuff.
There are various people on ebay doing short lengths if you want some to test in a hurry and don't mind spending a couple of quid.
Posted : 06/06/2013 12:10 pm
Yes, no problem Kaysee. Let me know if no luck with Viking and we can sort out an address and i'll pop some in the post
Posted : 06/06/2013 12:50 pm
Kaysee, I believe its the 4910 series stuff, 1mm thick. Hard to tell as there are no part numbers on the inside of the reel. Will confirm once I get hold of my purchasing dept. Would offer to send you a sample but it's a pain in the ass once taken off the roll and would probably be of no use once it had turned up.
http://uk.rs-online.com/web/p/double-sided-foam-tapes/7638807/
Posted : 06/06/2013 1:10 pm
Sorted! Viking are sending a few samples out. Thanks for the help - let see if it works!
Posted : 06/06/2013 2:09 pm
