does anyone know wh...
does anyone know where i can get a 15x130mm axle ?
[#13530613]
my front axle for my gravel bike is 15x130b - the axle has a quick release on it which i would like to loose as i will save weight and avoid it catching in things ( i *always* have tools on me as i need it for the rear)
I have been hunting about on aliexpress for a Ti version but to no avail ( and even the robert axle project)
anyone know where i can get one of these ? its off of an Orange RX9 and i dont want an exact replacement i want one without the QR lever ( or a fancy hidden QR)
Posted : 13/06/2025 7:33 pm
 PJay
I think you need to know the thread pitch too. Orange have lot of rear thru-axles on their shop, but no fronts, they might be worth a shout though.
The geometry page for the 2023 RX9 shows Length-152mm, Thread-20mm, Pitch-M12X1.5 for the front axle, but I'm not sure if that tallies with what you have there.
Posted : 14/06/2025 8:25 am
thanks its weird that on their site they list it in 1 place as a 12mm axel and somewhere else as a 15mm - its definitely a 15 🙂
Posted : 14/06/2025 1:43 pm
 PJay
There was a fork recall at some point & I think originally it was an all aluminium fork rather than carbon bladed,  so things may have changed.
Posted : 14/06/2025 1:58 pm
What is the other end like? Is it a captive part of the fork (i.e. threaded leg) or a nut that falls off. If the later I think you struggle to tighten properly without a qr.
There is someone makes 15mm to 12mm axle conversions for gravel/road bikes, they may do something that will work. https://jjpne.com/fork-conversion-kits/
The weight saving is minimal btw
Posted : 14/06/2025 2:47 pm
Posted by: Daffy
The Robert Axle Project will sort you out - not cheap, though.
httpRobert Axle Project s://robertaxleproject.com/product/lightning-bolt-on-axle-front-15-mm-x-130-mm-x-1-5-thread/?srsltid=AfmBOopedXBavzuAI9Wr3xe2dSASvoJxiBV0Es9SRwA33MDnHJMVCfQL
*thank you* I must have missed that one on their site ! I think that they are the only one doing them so will order from them
Posted : 15/06/2025 7:25 pm
SJS cycles are the UK seller of Robert Axle Project.
Posted : 15/06/2025 9:00 pm
