Dodgy Kryptonite Ev...
[Closed] Dodgy Kryptonite Evolution lock
[#7099383]
After getting my bikes stolen last year, complete with locks, the insurance paid out for new locks. I bought Fahgedaboutit chains with Kryptonite Evolution Series 4 locks.
This morning I had a bit of a fright when I couldn't unlock one of them. For 10 minutes or so, I struggled and eventually it unlocked. The key only turns 90 degrees instead of the full 180.
As I have 2, I swapped the D part of the lock over, and the problem transferred with the D, ie - it now happened with the other locking mechanism.
At a bit of a loss as to what the problem could be. Anyone experienced similar and can anyone recommend a different, decent lock?
Thanks
Posted : 30/05/2015 7:03 pm
Tried a drop of oil/squirt with GT85?
Posted : 30/05/2015 7:05 pm
Yeah, tried that, ta. I read somewhere that you can stick a screwdriver in where the keys go, to align the discs within the locking mechanism, but it seems strange that it happens on both locks, using the same D.
Posted : 30/05/2015 7:08 pm
My new yorks do this from time to time,
Lube where the d pushes into thenlock body and open close the locks a number of times without the d in.
Frees them up no end.
Posted : 30/05/2015 7:13 pm
Thanks, I'll try that. As you can imagine, I did get the sweats this morning when I couldn't unlock the bikes. 😆
Posted : 30/05/2015 7:15 pm
Common problem with Kryptonite locks. The way to fix is to use a tiny flat bladed screwdriver to realign the lock bits. Then it's an easy fix. Only problem is I don't carry a tiny screwdriver around with me. Just the fing key! I've stopped using mine in favour of an abus lock.
Posted : 30/05/2015 7:47 pm
Thanks. Yes, I think I might do the same.
Posted : 30/05/2015 10:01 pm
