do rims matter?
[Closed] do rims matter?
[#4838275]
Is it fine to use road bike rims for a mtb? or is that just asking for trouble?
Posted : 05/02/2013 4:54 pm
You'll probably get your head kicked in by the trail crew.
Posted : 05/02/2013 4:55 pm
[i] is that just asking for trouble?[/i]
if you're prepared to run road width/cross bike tyres then it'll be fine.
If you want 'proper' mtb tyres then a wider rim is required.
Depends on the rim, your weight, and your bike handling finesse.
Posted : 05/02/2013 4:56 pm
i used the front wheel off my roadie at strathpuffer as it was easier than taking the tire off the rim and mounting it on a stans arch.
road bike wheel was heavier than my stans arch 29er anyhoo
Posted : 05/02/2013 5:04 pm
My Open Sports feel pretty dang sturdy. And they're only about 40g lighter than a 29er 719.
Posted : 05/02/2013 5:07 pm
width is an issue.
Posted : 05/02/2013 5:08 pm
Your tires won't fit 😛
Seriously, I ride Open pros on my 29er (rigid) no issues so far.
Posted : 05/02/2013 5:11 pm
It's a 29er, i think 2.1 width. 15 stone. no bike handling finesse. just dont want to be going back again in a month for yet another wheel build
Posted : 05/02/2013 5:25 pm
15 stone, no handling finesse probably fine. Combine this with Rocks, Drops and the odd jump. Personally I would be getting some proper MTB rims - DT470's, Mavics, Stans Arch or Flow (probably not Crests).
Stainless spokes and brass nipples.
If you need to save that much weight - there are some other ways that I am sure others may be happy to volunteer.
Posted : 05/02/2013 5:54 pm
I'd be worried about tyres that wide rolling off the rims unless pumped up really hard too.
Posted : 05/02/2013 5:55 pm
 mrmo
some of the first decent MTB rims was a re rolled MA40s.
you'll be fine unless you want to run 3" tyres
Posted : 05/02/2013 5:57 pm
