Do I really need an...
[Closed] Do I really need an eyelet bushing fitting tool
[#5403258]
Do I really need an eyelet bushing fitting tool to fit my new HD bushings I just bought.
I do not have a vice.
Posted : 08/08/2013 9:00 am
nut and bolt with some washers will probably do it or just bashing with a hammer.
It's a bit like headsets, I guess - how lucky do you feel?
Posted : 08/08/2013 9:03 am
For a shock? Not necessarily, but for the sake of less than a tenner they're worth it IMO. I bought one similar to [url= http://www.ebay.co.uk/itm/Shock-Bush-Removal-Tool-DU-Bushes-for-Fox-Manitou-X-Fusion-5th-Element-/111136085089?pt=UK_sportsleisure_cycling_bikeparts_SR&var=&hash=item19e03a1461 ]this[/url] a while ago and it works really well. Came with some bushes too.
Posted : 08/08/2013 9:15 am
You have High Def bushings, cool.
Posted : 08/08/2013 9:18 am
as per tonyd, I've done it DIY and with the tool, for the cost I'd buy a tool. There's any number on evilbay for not a lot of cash.
BTW a G-clamp will work as an alternative to a vice, you tend to need 3 or 4 hands though to juggle everything and keep it straight.
Posted : 08/08/2013 9:29 am
I've got the tool tonyd linked you to and from that seller, definitely recommended for the money.
Posted : 08/08/2013 9:34 am
Hi Chaps, thanks for the info. Just bought the one tonyd recommended.
Posted : 08/08/2013 9:48 am
Thanks for that, I need to replace them on my shock and was going to go to LBS. Will but the tool in the link above, looks more accurate than a hammer and socket!
Posted : 08/08/2013 11:16 am
I purchased one for about £ 7 from ebay it was a joy to use made the job very simple.
Posted : 08/08/2013 1:12 pm
I’m getting the fettling bug now, just watched a video on how to change my swingarm bearings. Need to buy a mallet now.
Posted : 08/08/2013 1:54 pm
Just changed mine. I have this tool:[url= http://www.ebay.co.uk/itm/Shock-Bushing-Tool-for-rear-Fox-Rock-Shox-Marzocchi-2x-DP-Bush/271246204718?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D286%26meid%3D419246764885068570%26pid%3D100005%26prg%3D1048%26rk%3D1%26rkt%3D5%26sd%3D111136085089%26 ]£9.50 with two bushes[/url]
I generally bodge stuff and full range of sockets, studding and string but this tool really makes sense. Takes about 5 mins and no need to take the shock off.
Posted : 08/08/2013 4:07 pm
Inormally make my own pullers for most things but for the shock get the £10.00 threaded tool. Don't be tempted by the cheaper drift. hammers have no place near shock stansions IMO.
Posted : 08/08/2013 4:16 pm
Also use the tony d linked one and it is simplicity to use
Did not fancy mallets and drifts on my shock either
Posted : 08/08/2013 4:31 pm
Might I recommend [url= http://www.ebay.co.uk/itm/Shock-Bushing-Tool-for-rear-Fox-Rock-Shox-Marzocchi-bush-/271246205031?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item3f2788a067 ]this [/url]one on eBay - purely because I know the fellow that makes them!
EDIT: The same one that nickjb suggested but without the bushings included!
Posted : 08/08/2013 4:38 pm
I bought the one that househusband and nickjb recommended, last week and it worked a treat.
Posted : 09/08/2013 10:20 am
Folks, thanks for all the info, bought the bushings and tool, fitted at the weekend, a bit of faffing about, but sorted.
Many thanks.
Posted : 20/08/2013 4:11 pm
