Do I need new pads ...
[Closed] Do I need new pads if I’m fitting bigger rotors?
[#11907475]
As per the title. I’ve got some single-pot SLXs running on 180mm rotors. The pads are only a handful of rides old (metal up front, resin out back). I’m thinking of sizing up to a 203mm rotor on the front as it seems like a very cheap way of getting more power on heat dissipation for very little outlay or extra weight.
Do I need to factor in new pads too, or can I just pop on a new (bigger) rotor? Obviously not wanting to go throwing another £35 for pads (if I can even find anywhere with stock) if the current ones will play nicely with the bigger rotor.
Posted : 02/06/2021 7:47 pm
Just use the existing ones till they wear out. Perhaps give them a clean / refresh with a bit of sand paper to take the crap off the face of them. But there is no point binning them. Also make sure the new rotors are clean. I use disc brake cleaner. Then do a couple of hard DH braking runs to match the clean pads to the new rotors.
Posted : 02/06/2021 7:57 pm
New rotor and new mount adapter
Posted : 02/06/2021 8:02 pm
Aces. Thanks for the confirmations. Was worried the pads would wear to the “signature” of the rotor.
…or a boatload of washers?
Posted : 02/06/2021 9:20 pm
Your joking about the washers, presumably! Definitely adaptor required!
Posted : 02/06/2021 9:37 pm
