I need a new chainring for a SRAM set of cranks, look to me like some form of direct mount one is in order. When I started looking it seems there are both Boost and non-Boost. Is there really a difference?
Posted : 21/10/2019 2:41 am
Yes. From memory boost is set 3mm further out. Someone will confirm.
Do you need it though? Possibly.
Some frames are perfectly happy to run a non boost set up if clearances are fine. Chain line is also better if you can get away with non boost.
Posted : 21/10/2019 3:19 am
Thanks Poop,
I will go and see if I have 3mm to spare, i suspect not though.
Posted : 21/10/2019 4:57 am
