Do I cut this chain...
[Closed] Do I cut this chain to short?
[#10562424]
Just converting a friends bike to 1x. I followed the big + big + 2 rule but wondering if it’s a little short? Photo is with the shock fully compressed.
Posted : 02/04/2019 2:16 pm
I've always used biggest cog to crank (direct) plus two full links although with clutch mechs that may have changed.
Posted : 02/04/2019 2:20 pm
I would say so...i tend to judge chain length by what it looks like on the smallest cog...but if it shifts OK then it'll be fine.
The cable also looks a bit on the short side to me...i'd prefer to see a bit more slack there
Posted : 02/04/2019 2:21 pm
Looks fine to me. 👍
Posted : 02/04/2019 2:22 pm
I thnk one more link would be ideal but that is OK.
Posted : 02/04/2019 2:25 pm
Thanks everyone
Posted : 02/04/2019 2:34 pm
I'd keep my eye on the brake hose too.
Is there any slack up front you can pull back for both gear cable and brake hose
Posted : 02/04/2019 3:42 pm
 geex
it's the correct length.
No one bottoms out (properly set up) rear suspension riding in their lowest gear.
Longer chain = less spring tension from the mech cage = more chain slap/flap in the highest gears.
Posted : 02/04/2019 3:45 pm
Cheers. I’ll have a play round see if there is any slack on the cables.
Posted : 02/04/2019 3:56 pm
Sometimes things don't go according to the plan. Best to have enough chain to be safe. That looks fine to me, wouldn't want it any shorter.
Posted : 02/04/2019 3:57 pm
From memory sram say 2 extra links for a fs.... 4 for a ht.
But remember, the chain growth is not always at its longest when she shock is fully compressed....
On my old Marin the suspension was about 2/3 compressed to get chain growth at maximum.
Not saying it's the case with your bike but it's worth remembering.
Posted : 02/04/2019 5:00 pm
i'd put one more link in especially if it's a NW ring, that and the clutch mech will take care of the tiny bit of extra slack
Posted : 02/04/2019 5:26 pm
