It certainly seems so on some of them, and, to be honest, it makes a lot of them look rubbish in anything other than a small or medium.
Most seem to.
On the one hand it makes the weigh distribution different between sizes, on the other it's more to do with how far that COG is from the rear wheel (i.e. a tall person doesn't want a long rear end, he wants his/her COG the same relative to the wheel to make manualing* both bike the same), in which case having the same back end is correct.
*or pumping, or the stability induced by having the COG a given distance from the rear wheel through rougher sections, none of which are really related to the front wheel.
I was just looking (and this may be specific to 29ers with a shock ~inline with the TT/Seatstay) and in some of the larger sizes, it truly makes the frames look horrendous...
The Ibis Ripley for instance looks ACE in a small, but once it gets to a large, the SS isn't inline with the link, which in-turn isn't inline with the shock which in-turn isn't inline with the TT. It offends my OCD so much that even as a huge ibis fan, I can't bring myself to buy* one...
* I also don't have anywhere near the amount of money required for a Ripley, but that's beside the point...
Liteville have different chainstays for different sized frames. More to do with 'scaled sizing' than anything else.
Don't turn the front wheel the way your forward foot is!
Most do. Norco do not.
Your straight line theory is still off for that bike, the toptube is still not on a parallel line with the seat-stays, and it doesn't help that its a blobby carbon moulded shape.
Its a nice enough looking bike despite that though, because it doesn't break the 90degree rule (or at least by as much)
[edit] also anyone with actual OCD would be clawing their eyes out at that bike because it has 3 rims decals and only 2 tyre ones, so you cant claim OCD if you like the IBIS wheels[/edit]
STATO - Member
I've de-stickered all of my rims (except for the Archetypes as they're cool) as I can't stand it when irremovable tyre decals (especially gopping yellow ones ....I'm looking at [i]YOU[/i] Maxxis!) are shorter than rim decals....they should decrease radially toward the hub!
