Do 44mm headset cup...
[Closed] Do 44mm headset cup spacers exist
[#7861215]
Ok so non strait 44mm headtube but with a cup insertion dept of 9mm.New headset has an insertion depth of 10mm(SS Slackerizer external cups).Can you buy anywhere a 1mm 44mm I.D spacer.
Cheers all.
Posted : 31/05/2016 10:26 pm
bump
Posted : 01/06/2016 5:16 pm
Never seen one for sale, could you knock 1mm off the cup?
Jon
Posted : 01/06/2016 5:23 pm
The correct solution involves a grinder acting on the cup.
l.e. Except for this particular headset, that is :/.
Posted : 01/06/2016 5:24 pm
If you find someone with a lathe it is quicker to remove 1mm from the headset cup than make a spacer. It would also only take you a few minutes with a file (maybe just enlarging the chamfer would work depending on the inside profile of the HT).
Posted : 01/06/2016 5:27 pm
Get a ZS44 cup and have it machined into a ring of 44mm ID.
Posted : 01/06/2016 5:34 pm
YGM
Posted : 02/06/2016 12:18 pm
Send me the headset cup and a stamped addressed envelope (and maybe a fiver) and I'll turn it down on my lathe for you.
joe<AT>starlingcycles<DOTCOM>
Posted : 02/06/2016 12:23 pm
YGM Matthew. 😀
Posted : 02/06/2016 9:39 pm
what frame out of interest? Supposed to be fitting one to my solaris.
Posted : 02/06/2016 10:57 pm
The *much* easier solution would be to ream the headtube deeper. The park reamer we have can ream to around twice that depth if required
Posted : 02/06/2016 11:17 pm
@andyl: The Solaris' headtube is a 44mm ID cylinder, there's virtually no insertion depth limit on it. However, unless you have a straight steerer on your fork you won't be able to use a Slackerizer.
This headset is EC, but it is more like a ZS - the bearings sit inside the frame, any lathe cut on the bottom of the cup will most likely get you a nice sunny window facing the bearing.
Posted : 03/06/2016 6:29 am
Update.
After a quick measure of everything Superstars info is totaly wrong.The actual insertion depth of the EC cups is a tad over 8.5mm.There 10mm info includes the tapered end of the cup so slotted in a dream. 😀
Posted : 04/06/2016 5:32 pm
