DMR Viral guide - c...
[Closed] DMR Viral guide - cheaper to buy separately?
[#4336572]
I'm confused...I can buy this for
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=85038&utm_source=Google&utm_medium=Shopping&utm_name=UnitedKingdom ]Full guide[/url] £71
Or I can get separate bits for £51 - am I missing something??
[url= http://www.winstanleysbikes.co.uk/product/51622/DMR_Viral_Upper_Caged_Chain_Guide ]Upper[/url] £10
[url= http://www.freeborn.co.uk/dmr-viral-lower-only-single ]Lower[/url] £41
Posted : 06/09/2012 11:01 am
Don't know whether you'd be able to fit them both to one set of ISCG tabs?
Posted : 06/09/2012 11:03 am
Looking on the DMR web site looks like they're supposed to fit together? If it were me, i'd buy separate and take a punt!
Posted : 06/09/2012 11:24 am
That's what I thought - the £70 guide is in two parts that I think are supposed to be £40 each...CRC and others discounting heavily on split parts and not the full thing though
Posted : 06/09/2012 11:31 am
Looks like it will work to me with the recessed lower from Freeborn and standard upper, I believe the seperation is to allow adjustment on each independant of the other. Like mysterymove said the DMR site shows them mounted together so there should be no problem!
Posted : 06/09/2012 11:58 am
by the way you can't use the upper with a bash if you were planning on...
Posted : 06/09/2012 11:59 am
Both upper and lower on Winstanleys for £10.39?
Posted : 06/09/2012 12:05 pm
honourablegeorge - Member
That's just for the cages without the backing plate
Posted : 06/09/2012 12:08 pm
Lifer - Member
The descriptions and pictures suggest otherwise
Posted : 06/09/2012 12:17 pm
You can buy the full thing to use with a [url= http://www.dmrbikes.com/products/guides/viral-bash ]bash[/url], just need to find that bit separately and for cheap
Posted : 06/09/2012 3:44 pm
