DMR Vaults - which ...
[Closed] DMR Vaults - which one is RH/LH side
[#6524496]
Bought a pair of these and cant see any markings anywhere to denote which one is driveside etc?
Any clues?
Kwack
Posted : 02/10/2014 11:45 am
It'll only thread in one way round. Well, it'll thread in either way with enough force! But you can do it by trial and error
Posted : 02/10/2014 11:46 am
should be some markings on the end of the axles
Look at the threads.
[url= http://www.parktool.com/blog/repair-help/pedal-installation-and-removal-pw-3-pw-4-pw-5-hcw-16 ]Pictures here.[/url]
Posted : 02/10/2014 11:49 am
put them on the floor next to each other, stand behind them, the writing on the pedals should be the right way up...
if they arnt then they are the wrong way round, and you have the RH on the LH side...
Posted : 02/10/2014 12:22 pm
the wide edge is facing forward, the narrower one is on the back
Posted : 02/10/2014 12:23 pm
Drive side
Posted : 02/10/2014 12:37 pm
trial and error screws the threads up doesnt it
Posted : 02/10/2014 12:47 pm
Only if you actually force it into the wrong one. Which some folks will do to be fair, so it's advice to be taken with caution but done with any care it's absolutely fine.
Looks like there are other ways to do it with these pedals which remove even that risk though
Posted : 02/10/2014 12:52 pm
The non-drive side pedal has a groove around the 'flange' on the axle that tightens up against the crank.
Posted : 02/10/2014 12:58 pm
If someone can't see the difference between the threads without "trial and error" then they really, really need to step away from the spanners.
Posted : 02/10/2014 1:05 pm
I can't actually remember but i'd have thought it was obvious from the writing as you'll be able to read vault when on the bike and its not upside down....
Posted : 02/10/2014 1:09 pm
Very good - was trying to see whether there was a simple way to tell the difference. Previous pedals have had R/L on them..
I can see now that there is a difference as pointed out above - Without resorting to looking a the way the thread is pitched. I can build a bike like the best of em!!!
Do not do trial and error as this leads to stripped threads, mashed bolts,,,smashed bearings etc etc But thanks for teaching me how to look a a thread pitch
Posted : 02/10/2014 2:32 pm
Put one thumbnail in the thread of one of the pedals and turn the axle with the other hand. If clockwise makes it "screw in" that's the RH pedal...
Similar to trial and error but with no risk of the ham fisted messing up their cranks...
Posted : 02/10/2014 3:55 pm
Also, with any thread and any bolt, you really shouldn't be screwing the thread up.
Start out slow and careful with loosey-goosey finger tightening, if it's not going in squarely and with evenly increasing tightness (ie not loose - tight - loose - tight) something's wrong, back it out and try again.
If you've made a mistake you've got plenty of clues before you start to mash threads.
Posted : 02/10/2014 4:03 pm
There is no way you'd ruin anything by trial and error unless you're a completely ham fisted idiot and force the pedal in.
Posted : 02/10/2014 4:11 pm
