DMR V12 bush replac...
[Closed] DMR V12 bush replacement
[#8072321]
Just replaced the bushings on my V12's as they were worn and slack. Couldn't find a decent suggestion of how to remove them as they're impossible to knock out.
The DMR tool is just a thread, slightly larger than the bush I.D (12mm)
So I just used a length of 1/2" threaded rod, and screwed it into the bush (using two nuts screwed right against each other but a bolt would do)
You can then use one of the nuts to pull the rod/bush free by tightening it against the pedal body (use a washer not to mark it)
Or just use a vice (no nuts required) to pull the rod and bush out.
Easy! The bearings knock out with the axle, no tool needed.
Posted : 23/09/2016 8:55 pm
Brilliant. My bushings in mine are shot to "manure".
Out of interest where did you get bushings and what did you use to fit them back in?
Posted : 23/09/2016 9:02 pm
Oh, and here's a cheaper service kit
http://www.onlinebearings.co.uk/DMR-V12-Pedal-Service-Kit.html
Posted : 23/09/2016 9:18 pm
Awesome cheers. 🙂
Posted : 23/09/2016 9:21 pm
Read that reply after my second reply!
Pushed the bushings back in with the axle, but they're easy to drive in with a socket, handle end of an old screwdriver, etc
Posted : 23/09/2016 9:25 pm
