DMR pedals questio...
[Closed] DMR pedals question
[#1307083]
I recently fit some DMR pedals to a mates bike.
Today I noticed that the external shield [img] [/img](designed to create a seal between the Pedal Axle and main pedal body) has come loose.
There does not appear to be an obvious way to fix this - at first I assumed they were a press fitting but it would appear not.
Can anyone shed any light ?
Posted : 09/02/2010 12:31 am
Mine did the same. I just kept pushing them back on! Didn't seem to cause a problem.
Posted : 09/02/2010 12:44 am
yeha, mine have done that. I dont rate dmr pedals, I'll be buying new ones soon
Posted : 09/02/2010 12:51 am
Common problem. Not great pedals imo.
Posted : 09/02/2010 1:14 am
Congrats. You have just discovered that dmr stuff is mostly cheap guff.
Posted : 09/02/2010 1:44 am
 Keva
yeh they all do that. And you'll notice that there's only one bearing cartridge in each pedal when you come to replace them.
Posted : 09/02/2010 9:10 am
 br
If they are V12's just make sure you strip and fill with grease once they start to turn not-so-fluid - 10 min job.
Posted : 09/02/2010 10:26 am
