DIY rotor cleaning ...
[Closed] DIY rotor cleaning what should I use?
[#959554]
think my rotors and pads are contaminated,happy to fit new pads but want to clean the rotor before I do .
What should I use?
Posted : 17/10/2009 10:01 am
A dishwasher
Posted : 17/10/2009 10:03 am
Meth.spirt works well.
Posted : 17/10/2009 10:06 am
😆 like it!
Meths, IPA or something like that
Then again, a scrub with hot soapy water will do the trick too
Posted : 17/10/2009 10:10 am
I use spray on disc brake cleaner for cars from (cough) Halfords.
Works well.
Uplink: - I can see how meths might work but not Indian Pale Ale, bit of a waste as well
Posted : 17/10/2009 10:27 am
IPA (isopropyl alcohol here in case uplink *meant* the booze 😯 ) worked for me to stop a nasty case of squealing the other day...
Posted : 17/10/2009 10:34 am
Booze?
I wouldn't waste good beer on a bicycle 🙂
Posted : 17/10/2009 10:36 am
is there anyway of cleaning up the pads? A mate reckons soak them in meths then set them alight and let them burn themselves out and hat should do the trick?
Posted : 17/10/2009 11:09 am
i usually heat the rotors by riding with the brakes slightly on for a minute or two then throw cold water over them. seems to work. got the hint off a motocross buddy.
Posted : 17/10/2009 11:14 am
When I
ve used hot water with a little detergent to thoroughly wash my discs and then dried with a clean cloth or paper towel.Sanded pads with light wet or dry,until dirty deposits are no longer seen on the paper.Then replace and do some hard stops until they generate some heat.Worked for me!
Posted : 17/10/2009 11:48 am
