Discs and Campag
[Closed] Discs and Campag
[#3022916]
Suggestions please for Campag compatible disc hubs.Don't suggest Royce. 200 quid plus is a touch too much.
Posted : 06/08/2011 10:25 pm
fulcrum wheels and DT would be worth a looking at, I know you can swap over freehubs on the road wheels, MTB ones might use the same
system/free hub.
Posted : 06/08/2011 10:37 pm
 mrmo
Hope. They make the road wheels with campag free hubs now, i would be surprised if you can't swap.
Posted : 06/08/2011 11:11 pm
you might have to go pro3 to do he above though.
Posted : 06/08/2011 11:12 pm
Meant to say it's raod wheels i am building although doubt it really matters.
Posted : 07/08/2011 8:03 am
or just get shimano wheels and use a conversion cassette like american classic, i used a 10 speed campag one a few times on shimano wheels and it was fine
think I still have it
Posted : 07/08/2011 8:21 am
That is the reason why I am looking to swap hubs. I am using a 10 speed Shimano hub and cassette on my Cotic X with discs. Campag transmission though. Shimano splined, Campag 10 speed cassettes are few and hard to find. Ambrosio's would do but I can't actually find one.
All the various Shimergo options change the numbers of gears ie 9 from a 10 speed mech.
I'd happily keep t the Shimano splined hubs as this gives me a greater choice.
Didn't know about the American classic.
Want to part with yours?
Posted : 07/08/2011 8:37 am
same issue for me so I've just stuck with a Shimergo setup which works perfectly but does mean 9 instead of 10 speed. I have been considering the 10 speed ambrosio cassette but by the sounds of it maybe that's not readily available.
Posted : 07/08/2011 8:40 am
My 10 speed Shimano cassette works well with Campag 10 speed shifters but just a touch noisy and now I have got the system working I am playing with the small things.
Posted : 07/08/2011 8:46 am
hang on, i'll go and check the shed
Posted : 07/08/2011 9:18 am
It's a 12/25, had a little light use on my cross bike on a second set of wheels I used on the road, very rarely. I found it worked well and I didn't have to touch the gears to change between this and a wheel with an actual Campag cassette on.
Think it cost me about $100 from America strangely enough , yours for £25 posted if you like.
smcfarlane [at] gmail [dot] com
Posted : 07/08/2011 9:47 am
Either HOPE hubs, or Marchisio sprockets.
Posted : 07/08/2011 11:00 am
 Rik
I don't think the hope hub campag cassette body with the pro2s as the road hubs a slightly different.
I'm using Bonty Race Lite X wheels which are rebadged DT 240 hubs which I've put one of there campag cassette bodies on.
Works great but not cheap.
Posted : 07/08/2011 11:46 am
Restless, email sent
Posted : 07/08/2011 12:59 pm
