Disc six point hub ...
[Closed] Disc six point hub mounting - should spacing be standard?
[#9588279]
Hi
I’m in the process of converting the V brakes on an old bike I am renovating to disc. In the interests of keeping costs down, I was intending to use a spare front wheel I have that had a six-point disc mounting.
The calliper and disc arrived today – but on offering up the disc to the wheel, only one of the six holes in the disc align with the hub.
I found another 160mm disc to compare to the new disc, and the holes match identically.
I had assumed the 6-point mounting would be a standard thing – but this seems not to be the case.
Should the mountings be standard? Or have I just got a non-standard wheel?
Thanks
Posted : 04/10/2017 2:36 pm
Hope had 5 bolt, Cannondale had 4 bolt and Amp Research had 3 bolt but I don't recall another 6 bolt standard. What wheel / hub is it?
Posted : 04/10/2017 2:39 pm
What brand hub and disc?
Pics...
They *should* be six-bolt standard pattern, unless old Cannondale or Hope.
Posted : 04/10/2017 2:41 pm
I have a vague memory that my dad had a Marin of some kind with Diatech hubs on that had a different spacing to everything else on the planet.
Posted : 04/10/2017 2:49 pm
Thanks for replies. I'll try and post some pics later, but the disc hub is branded Dunlop (you can see this is a high value build!)
It looks like this:
Posted : 04/10/2017 3:13 pm
