Disc equipped cross...
[Closed] Disc equipped cross bikes.
 wors
[#2483085]
Whats out there at the moment? Sorry if it's been done before.
Posted : 18/02/2011 5:51 pm
Salsa makes one, Genesis has one or two... Give it six months though and there'll be many more now the rules have changed.
Posted : 18/02/2011 5:55 pm
new cotic
Posted : 18/02/2011 6:09 pm
can't wait for some decent carbon disc forks... come on Easton!
Posted : 18/02/2011 6:12 pm
reggiegasket - Member
What's wrong with the ones out there at the moment?
Posted : 18/02/2011 6:33 pm
The obvious choice, Uncle John?
Posted : 18/02/2011 6:39 pm
I spent several months weighing up what bike for my partner, I looked at them all, had a spreadsheet with standover calcs and everything on it, budget up to £1k. Almost bought a Cotic >X<, almost built a Kinesis Crosslight blah blah but eventually I had an epiphany (no, not an Ellsworth) and went to Halfords (I know!) & bought a Boardman Hybrid 'female informed' Comp; for the money (£399) you get a very, very nice bike that includes BB5s and Ritchey finishing kit. Easily upgradeable to drops if that's what you want to do and it takes 35mm Sammy Slicks and mudguards. Very impressed I am and a third of the price of an >X< with Tektro disc and Tiagra upgrades.
I did have to tighten a few bolts and reset the front mech though, even though it had been PDId.
Posted : 18/02/2011 6:45 pm
Wait till 2012 bikes appear, everyone and their dog will have a CX bike out with disk brakes on. Might even see nice hydro brakes (Shimano had a press event last week but an embargo until July).
Posted : 18/02/2011 6:57 pm
 wors
I had a quick look at the boardman, you can fit a decent sized tyre in there then?
Posted : 18/02/2011 7:32 pm
Easy maybe,...cheap? Not a chance! - Don't they come with MTB BB5s?
Posted : 18/02/2011 7:34 pm
This is all very upsetting to me. I spent ages getting a trimester frame with sti, some remote reservoirs and hope e4 brakes and now every is going to spoil my fun and make hydro disc equipped drip bar bikes.
Poo!
Posted : 18/02/2011 7:36 pm
What's a drip bar bike? God this phone is a pita.
Posted : 18/02/2011 7:42 pm
drip bars are a bit like edit buttons 😀
Posted : 18/02/2011 7:44 pm
More fun this way I thought Al.
Posted : 18/02/2011 7:47 pm
I'm with you there 😉
Posted : 18/02/2011 7:49 pm
Posted : 18/02/2011 7:50 pm
am mulling over these options too - disc equipped will be all the rage at the middle / end of this year, problem is i want a bike now.
Uncle John, certainly fitted my bill, but does not take discs
i was thinking of the kinesis tripster decade....
what about those kinda hard tail urban 29ers (mtb position, mtb components - fit drops...cx disc fork)
http://www.bikeradar.com/gear/category/bikes/urban/product/escape-m1-07-19618
Posted : 18/02/2011 7:54 pm
Yes, there's plenty of clearance with the 35mm tyres I fitted, at least 6-8 mm each side and radially behind BB and loads more beneath the fork crown and between the stanchions. The one I bought was a small, but I have no reason to suspect the dims will be any different on larger frame sizes.
Yes, maybe not cheap but at £399 with BB5s as standard it's not out of the question, budget permitting.
Posted : 18/02/2011 8:10 pm
Another option I considered was a rigid, geared Inbred monster-cross with Mary or Midge bars. I really liked this idea and if I was speccing my own I'd probably build something like that.
Posted : 18/02/2011 8:12 pm
Naranjada - Member
MTB BB5s have a different lever ratio from road BB5s, so they are of little use. Factor in brakes, drop bars, probably STIs (have you seen the price?) and you have a cobbled-together mongrel which has saved you very little.
Posted : 18/02/2011 8:16 pm
So you'd eed new calipers as I thought...does sram sti work with mtb deraileurs?
Still might work out cheap if you upgrade s/h...but the top tube's always going to be too long for a road bike...
Posted : 18/02/2011 8:41 pm
You can get long pull road levers - cane creek do some - and keep the mtb bb5 calipers, but that does rule out sti's. Dura ace bar ends to the rescue if you go down that route.
Posted : 18/02/2011 9:04 pm
My mate has a Whyte proto - as above they won't be the only ones working on stuff.
Posted : 18/02/2011 10:39 pm
weight, and to a lesser extent looks.
there are no 400mm C2A full carbon disc forks out there, sub 500g, as far as I'm aware.
There are heavier ones, and Trigon do a full carbon fork that is sub500g but it's 415mm C2A, which is too long for me.
I want to run discs on my roadie, but 700g is too heavy for it to be a go-er, given that the disc wheel and brakes will also add weight.
Posted : 19/02/2011 11:08 am
Ah - the 680g of the DC19 is too much for you.
Check.
Remember though - disc rims can be lighter than those with a braking surface and rim weight is more important than hub weight.
Posted : 19/02/2011 11:16 am
yeah it's close, with the current forks, but not quite close enough. All it'll take is a decent sub 500g full carbon fork and I'll go for it.
I want to build my version of something like this
Posted : 19/02/2011 11:27 am
i'm very excited by what will hopefully be available in the next year in this niche - my wish list is carbon frame & forks with racey geometry (not the mtb'ish versions that cotic & whyte seem to have produced). At a decent price - ragley on-one, planet x - purlease!
hydro brakes are likely to be trickle down so i should be able to afford in 2020...
Posted : 19/02/2011 12:04 pm
rg..
I think they've dropped it this year though. Just over 10Kg, but that's with Tiagra and T565s - I'm sure a bit of weight could be lost somewhere....
Posted : 19/02/2011 12:09 pm
Oh - and the 3T CX Disk fork should be available in a few weeks
Posted : 19/02/2011 12:13 pm
yeah I spotted that druidh. Didn't look cheap though... and the cable routing is a bit of a mess, but they're on the right lines.
Posted : 19/02/2011 12:26 pm
Ah - so you want light [i]and[/i] cheap ?? 🙂
Posted : 19/02/2011 12:29 pm
please.
I think £200 is about as much as I'd be willing to fork out (?) for a new disc fork (and could get past mrs gasket). The 3T one could be quite a big chunk more than that though.
Posted : 19/02/2011 1:18 pm
Something tasty will be along soon
Posted : 19/02/2011 1:21 pm
DC 19 actually weights about 750gm cut (well mine does).
Posted : 21/02/2011 10:37 am
640 grams carbon disk forks for 140 Euros
http://shop4cross.de/komponenten/gabeln/gabel-s4c-disc-eylets.html
Posted : 21/02/2011 10:47 am
Ok, so a half decent disc cross fork. How about CX disc rims then? Other than the Stans Alpha which IMO are silly expensive.
Posted : 21/02/2011 10:54 am
^ not much off the shelf, Mavic Speed City might be an option. But best to get some handbuilt.
Posted : 21/02/2011 10:57 am
That's what I'm talking about - rims to build with rather than complete disc 700c wheelsets.
Posted : 21/02/2011 11:00 am
I've been running a set of alu Mosso rigid mtb forks for about 6 months, incredible value at around £40 delivered, v light at around 600g IIRC..
[url= http://cgi.ebay.co.uk/MOSSO-MTB-Aluminium-Rigid-Straight-Fork-Disc-Only-Black-/120599704436?pt=Cycling_Parts_Accessories&hash=item1c144d7374 ]Mosso[/url]
They may well do a cross/road version if you contact them.
Pretty useful thread on 700c disc rims here:
http://www.singletrackworld.com/forum/topic/700c-disc-specific-rims
Posted : 21/02/2011 11:07 am
Why do you need specific cross disc rims ?? been racing/riding DT470 (??) 29er rims on my tripster... also had a set of ebay special carbon deep's built for tub's.
..best pic I can find of it.
Posted : 21/02/2011 11:16 am
You don't per se - simply figured that it might allow for a slightly wider but not heavier rim - agree that a 29er one might be the way to go - the DT470 as you suggest being a decent example.
Posted : 21/02/2011 11:18 am
JD - I looked at those - not too stiff/harsh?
IMO they are not. You save 75 gm over an open pro for a premium of about £48 - that's rotating weight.
Seems a cheap way to save weight to me. Not bothered about braking surfaces either - makes re-sale easier and means the wheel is more versatile, but I'm not too bothered by looks.
So I've heard 😉
Posted : 21/02/2011 11:20 am
Al - should have also said that I consider expensive rims silly FOR ME because I have trashed a few in the past. Prefer not to spend too much on them for that reason.
Posted : 21/02/2011 11:21 am
