Disc brake silicone...
[Closed] Disc brake silicone lube
[#1702449]
Hunter Plastics SC960 / SC966 silicone drain fitting lube has been mentioned on here before as the stuff to use on sticky disc brake pistons - but where to buy??
Cant find in B&Q. Do any of the big plumbing / building trade places sell it?
A few online bike suppliers, but ideally want to pick up today for some vital evening bike TLC
Posted : 14/06/2010 10:46 am
Plumb Centre sell airesol silicone lube - it's used to build up push fit drainage pipework. £7 a can, ish.
Toolstation and Screwfix probably sell it too.
Alternatively, Aldi sell silicone lube in a pot like Finish Line lubes.
Posted : 14/06/2010 10:51 am
The only grease that would go near my pistons is Red Rubber Grease. Anything else is likely to swell the piston seals and cause problems.
Posted : 14/06/2010 10:58 am
The stuff referenced in my OP is what Hope use during assembly at the factory - so should be suitable...
Posted : 14/06/2010 11:04 am
... just need to be able to get hold of some...
. bump
Posted : 14/06/2010 11:59 am
Best bet is to ring around local plumbers merchants.
...or buy it [url= http://shop.parkerbs.com/product/Hunter_Lubricant_250ml_SC966_L01000 ]online[/url] and be patient.
Posted : 14/06/2010 12:12 pm
What's wrong with "3-in-one" silicone spray lube from B&Q?
Posted : 14/06/2010 12:32 pm
If you've got a scuba diving shop locally then they'll sell it as it's used for a lot of O-ring seals on diving equipment - but if you think LBS prices can be OTT then try an LDS!
Posted : 14/06/2010 12:36 pm
Managed to get some from the local Drain Centre. the guy did look quite alarmend when I said I wanted it for disk brake pistons...I think he had visions of me tinkering with my car or motorbike brakes.
Posted : 14/06/2010 1:46 pm
I've used the Plumb Centre own brand stuff on loads of Avid brake callipers - Juicy, Elixir, Code and Ultimate - without issue. Freed up several 'seized' callipers too. However, I do use Sram's Dot Grease when I strip down and rebuild them.
Now I've said that my brakes will explode on this evening's Curry Cruise!!
Posted : 14/06/2010 2:09 pm
