Disc brake advice p...
[Closed] Disc brake advice please......
[#1578186]
Even though the Juicy Ultimate is listed as an XC brake, will it be ok for AM if i use larger rotors??? what you say? 🙂
Posted : 05/05/2010 11:28 pm
It'll probably explode. You need to look for an AM-specific brake.
Posted : 05/05/2010 11:30 pm
i wondered that. But then, dont the athertons use xtr brakes on some of their bikes??
Posted : 05/05/2010 11:35 pm
I might have been being sarcastic.
Posted : 05/05/2010 11:37 pm
oops 😳
Posted : 05/05/2010 11:43 pm
anyone else?
Posted : 06/05/2010 12:54 am
Should be ok, take it all witha pinch of salt...try it and see, if they cook, then, hey, change, if not, stay put....don't believe the hype...
Posted : 06/05/2010 1:01 am
wots "AM" ?
Posted : 06/05/2010 1:28 am
nah they will be fine, if your bovvered whack some bigger rotas on their boi!
Posted : 06/05/2010 1:33 am
Stop being pedantic simon 😉
Was that the most grammatically incorrect post ever?
Posted : 06/05/2010 1:34 am
 ro
Perhaps... but there affect wasn't bad. Its simply confusing. Your being silly, NickyB
Posted : 06/05/2010 1:46 am
Larger rotors - heat up less but you will have reduced modulation.
Give them a good bleed too and get some decent pads in. I found sintered pads were fine in the Alps in my XT brakes and didn't even get through a set of pads. I don't brake much though.
Posted : 06/05/2010 7:00 am
NickyB is NOT MarkDatz!
Posted : 06/05/2010 8:11 am
