Disc brake adaptor
[Closed] Disc brake adaptor
[#6387981]
I've always had forks with IS caliper mounts. I now have a Rockshox SID fork wih a post mount. What adaptor do I need for a 200mm rotor?
Posted : 05/08/2014 11:19 am
A post mount to post mount +40 like this . . .
Posted : 05/08/2014 11:22 am
Does anybody know if you can use a 203mm adaptor with a 200mm rotor?
Posted : 05/08/2014 11:39 am
No, the pads will stand proud of the rotor by 1.5mm and as the pads wear they'll develop a lip on the outer edge which after a while will touch each other and your brake will stop working..
Posted : 05/08/2014 1:32 pm
OP are you sure you want to put a whopping 200mm rotor on a SID fork which is a lightweight xc fork?
Posted : 05/08/2014 1:37 pm
Short answer is no, I don't, but the longer answer is that it's cheaper than the alternative and still within SRAM's recommended maximum 😉
Posted : 05/08/2014 3:23 pm
i didnt realise an xc fork would be allowed to run such a big rotor...i would have thought 180mm would be the max.
Posted : 05/08/2014 3:58 pm
Float 32s allow for a 203mm rotor....
Posted : 05/08/2014 4:12 pm
