Difference between ...
[Closed] Difference between mavic 317 517 and 717?
 SiB
[#4956456]
Briefly what is the differnce between these three?
Is it the case of the higher the number the lighter and more expensive they are?
Thanks
Posted : 13/03/2013 2:23 pm
The first digit denotes quality. The second two denote the internal width. The quality is determined by the production process, alloy used and the method for joining. Higher quality rims I think are pinned and welded. Lower ones are pinned and I think glued?
An 8 denotes the rim is UST compatible.
So yes, the higher the number the higher the quality and therefore the lighter and possibly stronger the rim will be.
Posted : 13/03/2013 2:26 pm
 SiB
Thanks geetee, explained perfectly to a layman
Posted : 13/03/2013 2:32 pm
