Difference between ...
[Closed] Difference between Casstte 10 Speed 12-25 and 12-27??
[#3739788]
I would like to know which one to get on the shimano 105 5700 Groupset if using the chainset 170mm 39/53 option.
Any help please.
Thanks
Posted : 04/03/2012 7:43 pm
12-25 is pretty well the standard.
A 12-27 will give you that extra little help with a climb, as I see your running a standard chainset.
Simple as that.
I don't mind admitting that I might get a 27 for next winter.
Posted : 04/03/2012 7:49 pm
My new bike's got a 12-25 on it and tbh I just think it's bloomin silly. But then I'm not much of a roadie. So you should take this all with a pinch of salt but the only 3 thoughts I've ever had on the gearing selection are 1) Could do with a slightly higher gear. 2) Could definately do with a few lower gears. And 3) I'm fed up of double shifting.
Proper roadies/crossists may disagree.
Posted : 04/03/2012 7:59 pm
Main difference is that my middle aged kness prefer the 12-27
Posted : 04/03/2012 8:08 pm
OP what gears are you used to?
Posted : 04/03/2012 8:21 pm
Thanks for the advice.
Posted : 04/03/2012 8:30 pm
