Diagnose my Reverb ...
[Closed] Diagnose my Reverb problem
[#7593767]
Having an issue that I've not come across in previous threads here or elsewhere.
Basically the post sticks down a bit for the fist inch or two of its travel, but works fine once gently pulled to begin movement.
Air pressure and bleed status fine. Had a service not too long ago. Not clamped too tight (it's actually off the bike).
Posted : 21/01/2016 3:28 pm
Try another few bleeds.
Posted : 21/01/2016 3:32 pm
I've only ever seen that with the clamp over-tightened, but you've ruled that one out pretty conclusively.
Is the return speed slow after the initial "help"?
If it's quick, then it's not likely to be a bleed issue.
I'd go straight to warranty, assuming it's still covered. (2 years)
Posted : 21/01/2016 4:53 pm
turn the slow/fast adjuster to faster?
Posted : 21/01/2016 5:38 pm
burp it 5 or 6 times Stace 😉
Posted : 21/01/2016 5:54 pm
If it popping up fast after you nudge it to get it moving if so I would guess it doesn't need a bleed but maybe you have dirt/moisture/grit in it's mechanical contact bits-ie the delicate lower bushing(gets effed up easy and coating pulls off),keys and sliding channels.Remedy is a quick strip/clean and re-grease with maybe a basic service kit being needed if that lower bushing is toast.
Posted : 21/01/2016 5:58 pm
