Is it possible?
Ideally I'd like a new (road) bike, but gonna save and get something next year, but as a stop gap thinking of putting a new groupset of my 10yr old DeRosa..
So, is it possible to out Di2 on it?
Without too much bodging?
I should think so. You need to choose external wires and battery .
Shimano make an external wiring kit with downtube covers for the wires. As above, you mount the battery on a bottle cage mount.
Or you could drill holes in your frame 😉
Or SRAM ETap. You can buy just the duralliers and levers rather than the whole groupset. Probably cheaper than Di2 and alot less hassle with no wires, external batteries.
Not when everywhere is doing it for 47% off rrp.
Considering the dremel option here on an older carbon frame.
i've done a few conversions for customers and it looks properly grim with the self adhesive trunking all over the frame, and zip ties to keep wires away from rear wheel.
You can buy Di2 mechs/shifters.
Having said that I do like the logic of SRAMs shifters rather than having the buttons mimic the cable versions. Guess it depends weather you switch bikes often and how quickly you can get used to it, the SRAM system would be a nightmare if you didn't adapt quickly or fit it to all your bikes.
GCN review seems to suggest it's quite intuitive and doesn't take long to get use to. I'd probably go for it but want it for a time trial bike and the buttons and blip box seem a bit of a mess.
Anyone bodged internal di2 onto a frame that was meant for internal mechanical only?
It looks a lot neater on a black frame like Dirtyrider's, because you can't see the wires. On a white frame it looks a bit crap IMO.
As an aside seeing Dirtyrider's - you can put the ANT+ adapter in the BB shell, plugged into the junction box, works fine! Can rattle a bit, so you may want to tape it in, looks neater. Only works with internal routing obviously.
Can't see why it wouldn't work. May have to drill out some of the cable stops slightly so that wires go through rather than just cable inners. Need reasonable access at the BB too to fit everything in.
Can you run the Di2 cables through cable outers (or similar) to give a little more rigidity, use the existing cable routing and avoid excessive cable ties etc?
BB I think is a problem, I think it's a solid shell. Need to do some investigations.
I might be wrong but I have a feeling you can buy an adaptor that will let you mount the internal seatpost battery next to the bottlecage..
This is a good thing as you can charge and flash via the internal battery charger which is cheaper.
Otherwise you need the external battery charger and seprate interface and tbh the external batteries orrible to look at.
DoD
Would be horrid on a time trial bike! Going to try and bodge it into the seat post if I can.
Di2 cables are thin but the plugs aren't btw and they arent cheap ...
about £12 and you need 6
1 for batt,front dr/back dr then 1 to front junction and 2 to shiftrs.
Theres an external under bb junction bracket you may be able to use.
