Very cool, although I'm not entirely sure why one would want to do such a thing 😆
We need more details though!
Cheers, Rich
go on then, more details,
I dare you, no, I DOUBLE dare you, to set things up so that it tweets your location whenever you change into the granny ring.
Nice.
Just needs some voice activation now.
Are you able to change someone else's gears from your phone?
Everyone needs an app to change gears 🙂
It's part of a bigger plan where the phone app also reads power from a stages power meter, compares the output of the meter with a target power and then select a higher or lower gear to try and match that.
The idea being during say intervals or best power profile over a route, you just pedal at the cadence you want, the phone makes sure you're putting out the appropriate power.
Only if I throw the phone at their gear shifters or discretely plug the unit in when they're not looking :),
From a totally geeky perspective - this is very cool. Please share more info - how, etc?
Love the idea!!
like this?
http://lavamagazine.com/proshift/
Fairly easy. I've looked at the actual Di2 comms protocol in the past and decided it was too complicated to reverse engineer, so instead took the guts out of a DI2 satellite shifter and connected it to this http://www.rfduino.com/product/rfd22301-rfduino-ble-smt/index.html
which has been programmed to emulate the buttons being pressed over a bluetooth low energy connection. The biggest problem was getting the thing to drop down to a low enough current consumption when not in use that it wouldn't drain the battery - so there's also a movement sensor in the box to solve that.
Interesting!!
like this?
yup, but in theory better as it will use location based information from the phone to choose the power level. The proshift is using a preset power range, but for best speed for a given power budget you want something which selects different power levels for different gradients.
In theory you should be able to uploaded a power plan from say bestbikesplit.com onto onedrive, and the phone will then just follow it.
thats awesome 😀
"Siri, change down two gears".
And at 1439 it became self aware and in a panic Ian Munro changed gear first, Di2NET struck back, 52:11 on a 25% climb was very messy.....
