DHX rebuild questio...
[Closed] DHX rebuild question.
[#4947440]
Just finished rebuilding a dhx 5. Stuck 90psi in the piggyback. Now without the spring on i can compress the shock by pushing it against the wall upto about 1.5" from the end of the stroke using all my weight. Its stiff, is that right or have i got air in there?
Dont want to go put it on the bike cos its a pita to fit to find out its wrong.
Posted : 10/03/2013 10:09 pm
Wouldn't air in there make it easier to compress? Does it squelch when you do this? Pop more air in the boost valve and see if it gets stiffer.
Posted : 10/03/2013 10:12 pm
Yeah i had 150 in it to start off and i could hardly move it. So its working just wondering if its overly hard for some reason.. should i be able to compress it to bottom out without a spring?
Posted : 10/03/2013 10:20 pm
Have you got the damping wound off? Did you use the correct oil viscosity? Have you altered the shim stack order?
Mine will fully compress without a spring. Are you sure you've not over filled it?
Posted : 10/03/2013 11:50 pm
Everything is wound off totally. Used 7.5 wt shim stack in same order.
IFP set at correct height so cant overfill it.
Posted : 11/03/2013 12:46 am
Where did you buy all the seals from? Thought they weren't available to buy. Can you send a link please?
Posted : 11/03/2013 1:18 am
Took them to a local industrial fasteners place.
Posted : 11/03/2013 1:44 am
I would ask if it's a high ratio shock but mine is 3:1 and that will fully compress by hand.
I'm sorry, I'm running out of ideas.
Posted : 11/03/2013 4:22 am
