dhx coil 5 question
[Closed] dhx coil 5 question
[#2350463]
whats the max preload that can be achevied. read more than two turns can cause damage???
Posted : 09/01/2011 3:24 am
 GW
little preload means:
supple at beginning of stroke
solid in middle stroke
better bottom out protection
high preload means:
may be harsh at beginning of stroke
supple in middle stroke
may bottom due to lower spring rate
if you're needing more than 3 turns to achieve your prefered sag I'd buy the next spring rate up.
Posted : 09/01/2011 3:38 am
