Dhx air Vs coil?
[Closed] Dhx air Vs coil?
[#2687103]
How much weight will I save with an air shock over the dhx5 (with a steel) coil I have on board?
Posted : 24/04/2011 8:44 am
At least a pound, probably more. Depends on how big your spring is.
Don't get a DHX Air though, they're rubbish
Posted : 24/04/2011 9:37 am
 Taz
Went from DHX Air to coil on my Helius FR
The coil was soooooo much better. Was a few years ago so no doubt the air will have improved.
If I was to switch back to Air (which I won't)would go with RP23, if that is what they are still called.
My advice would be to stick with coil, get a Ti spring, and try and save weight / spend the money elsewhere.
Posted : 24/04/2011 9:48 am
Spring is a 550lbx2.35 unit.
The thing about saving the weight else where is that, I'm not sure where I can or want to reduce weight without [b]huge[/b] expence.
Wheel set = ztr flow on alfine11
SLX brakes
I guess I could lose a bit with chain, pedals, stem, seat post but that is minimal not the 6-8lbs that would make this build an "all mountain, all day, FR, miniDH, maintenance free, do-it-all" nirvana bike LOL
Posted : 24/04/2011 11:04 am
tyres would probably be a good place to start.
In your position i'd probably keep the DHX coil for gnar-core duties, and put on an RP23 or Monarch AM for trail riding.
Edit: I personally really loved my DHX Air, but they seem to be a bit of a marmite component!
Posted : 24/04/2011 11:15 am
Hmmm tyres. Yes, I guess.
Minion DHF & a High roller. swap them out for for something like a conti Deisel or a perhaps a nobby nic?
Posted : 24/04/2011 11:22 am
Try picking up a good used shock if you can, I bought one of ebay , 6 month old Vanilla R TFT'd for £90
Posted : 24/04/2011 11:24 am
crotchrocket - Member
Wether it's worth it for you depends which ones you have and how much you want to spend.
E.g. A DHF supertacky 2.5 = 1.3 kg whereas the 2.3 normal version is 'only' 0.8kg. The NN I think is about 0.5-0.6 kg so possibly not worth it if you have a 2.3 DHF, but an easy way to save 1.6 kg if you have the 2.5 supertackys.
There's a listing here of various parts and their real weights:
http://weightweenies.starbike.com/listings.php
Enjoy 🙂
Posted : 24/04/2011 11:51 am
