Detachable mud guar...
[Closed] Detachable mud guard?
[#10352646]
I have a regular Marsh Guard style mudguard on my front fork. Works great, no complaints with its performance.
Unfortunately, every time I put the bike in my car, it gets squashed and crumpled up (regardless of how I put it in the car). I'm sure I'm not the only one this happens to.
Are there any decent mudguards that can be clipped on and off easily somehow? I know I can use velcro straps on the Marsh Guards, but still a faff.
It looks like the Powa Dfender can be removed, but it looks a bit overkill and is pricey.
Thanks,
Duane.
Posted : 24/11/2018 11:47 pm
Rrp neoguard and leave it on?
Posted : 24/11/2018 11:49 pm
Shockboard can be quick released but it does tend to flap around on the standard mount (I always ziptie mine)
Posted : 24/11/2018 11:51 pm
velcro straps take 1 minute to put on and remove, not a huge faff in the scheme of things.
Posted : 25/11/2018 12:25 am
That's something that used to be common on sports bikes in the 1930s, back when they used the same bike for everything and rode to events.
A spring clip or two and wingnuts for the stays, in the right places and you could detach the guards in about 30 seconds.
I've been trying to get a good system worked out for my fatbike because getting it into the car with full mudguards is a PITA.
(I'm talking about proper big mudguards, not the short spray guards that are the common solution)
Posted : 25/11/2018 8:45 am
@epicyclo The PDW Mud Shovel clips on and off in a few seconds  https://www.charliethebikemonger.com/pdw-daves-mud-shovel-fender-rear-2964-p.asp  the biggest problem though is that the attachment mechanism is a fabric strap that tends to stretch over time.
Posted : 25/11/2018 9:27 am
Powa Defender is the only one ive found that actually works.  All the other clip on guards have broken or flapped around.
Posted : 25/11/2018 1:08 pm
I just have a crudcatcher on the downtube and the old inner tube trick on the suspension forks. Combo works great and no need to remove.
Posted : 25/11/2018 1:18 pm
I endeavoured with the Mudshovel for a few years but the bracket is poorly designed - to get it tight enough results in the cam pivot mechanism breaking.
Posted : 25/11/2018 2:14 pm
@dovebiker - mine fell off during last weekend's ride, err, hike-a-bike, I couldn't be arsed to go back the 100 metres or so and grab it. It really needs a proper clamp - there's only a few seat post diameters so design the clamp to fit the largest and ship with shims for the others.
Posted : 25/11/2018 2:34 pm
whitestone
The PDW Mud Shovel clips on and off in a few seconds ...
That looks pretty good for protecting your back, but doesn't protect your lower legs against spray, especially on a fatbike.
Not a problem on a shortish ride, but if you're out all day, the less wetness you get clinging to you, the less heat you use.
Posted : 25/11/2018 4:52 pm
 ART
This ... clean face in all conditions, it's worth the money.
Posted : 25/11/2018 7:36 pm
