Descent VFM Singles...
[Closed] Descent VFM Singlespeed Chainrings?
[#1971178]
Looking at CRC etc, decent (E-13/MRP/Salsa/Surly etc) singlespeed/1x9 chainrings are all £30 upwards which seems a little pricey. Are there any cheaper alternatives around?
Posted : 08/09/2010 1:12 pm
I'm currently using a cheapo FSA ring I got for £12.99 at my LBS. Replaced the cheapo one that had lasted me two years. I think the Surly stainless steel ones would last longer, but I wouldn't have thought expensive alloy ones last all that much longer than the cheapo ones to justify the cost really.
Posted : 08/09/2010 1:15 pm
got a not used much salsa one for 20 quid if you want dave 😉
Posted : 08/09/2010 1:17 pm
BETD/Goldtec DH Chainrings were £15 + postage when I last looked.
Posted : 08/09/2010 1:35 pm
What size Mick?
Ah, BETD. I knew I'd seen some cheap(ish) ones somewhere. I'll have a gander!
Posted : 08/09/2010 1:40 pm
its 104bcd 4 arm std shimano 32t mate
Posted : 08/09/2010 1:52 pm
I've had a couple of Blackspire ones that were good. You can usually get them for about £20 on CRC. Otherwise, I'm using one of the FSA ones mentioned above just now. It seems to be wearing a little faster than others, but it only cost about £12. If you factor in that Surly ones are reversible, as well as being harder-wearing, they are worth the money. It's worth considering a bash-guard though. They don't like rocks and logs, but you can bend them back into shape.
Posted : 08/09/2010 1:55 pm
Already running a bash. Will be in touch Mick. Brand spankers ones on BETD are £15 so might get one of those...
Posted : 08/09/2010 2:03 pm
Middleburn rings but without the slickshift machining are around £20 or so depending if you want the hardcoat or not.
Posted : 08/09/2010 2:05 pm
Well, in VFM terms I'd say the Surly chainring is probably the best, as while it might be about £30, it is made of stainless and they seem to last forever!
I've got one on my SS and it's been running on there for about 4 years now with only slight signs of some wear...
I'd say that's pretty good value for money to me!
Posted : 08/09/2010 2:11 pm
True. Plus stainless steel.... mmmmm, shiney shiney.
Posted : 08/09/2010 2:34 pm
surly are great til they bend , ive a surly bike covered in surly bits but not a surly chainring. cogs work well tho
Posted : 08/09/2010 2:42 pm
surly ones bend if a chainring bolt loosens, or if you're nice and lend someone a bolt 😡
alloy ones don't have that problem
Posted : 08/09/2010 2:51 pm
BETD are out of stock of 32T
Posted : 08/09/2010 3:40 pm
I'd still get Surly again, even after this:
I just hammered it back into shape 🙂
Posted : 08/09/2010 4:29 pm
that's not bent simon!
Posted : 08/09/2010 4:58 pm
Chainrings should come with a grr-manly rating.
Posted : 08/09/2010 5:32 pm
