Derailleur shim
[Closed] Derailleur shim
[#6896948]
Is it OK to use part of an inner tube as a shim on the front derailleur?
Posted : 27/02/2015 11:37 pm
You would need something more solid i would have thought.
What deraileur and diameterz are you needing?
Posted : 27/02/2015 11:40 pm
I have a sram X9 32mm clamp, too big for my wanga frame, so I assume it's 28.9mm
Posted : 27/02/2015 11:46 pm
Try it, I suspect it might be ropey.
Posted : 27/02/2015 11:51 pm
Coke can? A few thicknesses might work?
Posted : 27/02/2015 11:54 pm
Ashy are your coke cans 10 x the thickness of most? 😛
Posted : 27/02/2015 11:56 pm
Ha! Didn't read the bit about needing about 3mm worth of shimmage. Umm. Baked beans can?!...
Posted : 28/02/2015 9:02 am
My hybrid currently has a jubilee clip (with the screw bit cut off) as a shim - has been working fine for several years.
No idea what size clamp or seat tube are involved, though.
Posted : 28/02/2015 9:35 am
I've used a plastic pipe before and the shims you get for fitting lights to handle bars.
Worked fine.
Posted : 28/02/2015 9:36 am
Inner tube makes it hard to get the derailleur on perfectly straight in my experience as the tube does not compress evenly when you clamp it up, it worked but worked much better in terms of rub/rattle when i butchered the plastic spacer from a different sram derailleur to fit the one i had.
Posted : 28/02/2015 10:07 am
2l bottle of fizzy pop, drink it then go to town with the scissors.
Posted : 28/02/2015 10:22 am
I've used by inner tube for this before and had no problems at all. Go for it.
Posted : 28/02/2015 10:46 am
 Sam
3mm difference in dia means 1.5mm thick shim required. You want something solid, i.e. not a rubber inner tube. I have some thin Al strip I got from Wickes or some such that I use for this kind of job. I have also used the offcut end of a steel steerer sliced in half then hit a few tims with a hammer to get the diameter right. Steel will rust unless treated though.
Posted : 28/02/2015 10:47 am
