Deore disk brakes t...
[Closed] Deore disk brakes too grabby after service
[#10692233]
Hey all, wondering if anyone can advise..
Standard deore brakes just serviced are now far too on/off at low speed leading to accidentally braking far too hard.
It there any way to get more modulation and/or lever travel?
Cheers.
Posted : 30/06/2019 3:07 pm
Just remove a little fluid. It's a personal preference thing. Many folk (me included) like to have little/zero lever travel and would argue that anything else is a poor bleed 😉  I used to over-fill my brakes.
Posted : 30/06/2019 3:27 pm
Just get used to it.
Posted : 30/06/2019 3:53 pm
 tdog
Give it all of 5 mins until fluid weeps then hey presta!
Posted : 30/06/2019 5:19 pm
 poah
push the pads back so the pistons move into the caliper. this will increase the lever pull required to engage the rotor.
Posted : 30/06/2019 6:23 pm
Sounds like that could be an option.. Any guides or is it just take the wheel off and lever the pads with a broad screwdriver or knife or something.. Like can you push them too far and get into trouble?
Posted : 30/06/2019 6:39 pm
I use clean(ish) plastic tyre levers, save any damage to the brakes... especially if I have removed the pads and then push the pistons in.
Posted : 30/06/2019 8:16 pm
