deore chainring com...
[Closed] deore chainring compatibility help
[#2168817]
Do deore m590 or SLX, XT rings fit old school deore m510 square taper cranks?
All 4 bolt and same bcd
Posted : 08/11/2010 1:48 pm
Should do,but may need a touch of filing as sometimes the seat on the crank is a slightly larger diameter.
Posted : 08/11/2010 2:36 pm
Hants,
Stick to Middleburn standard CD-4 (or Deore rings and file down the excess material inside the bolt circles) to fit the older M510 cranks.
Do not try to file/grind the XT or SLX carbon composite rings.
It will only end in tears.
PaulD
Posted : 08/11/2010 2:55 pm
