Dent near bottom br...
[Closed] Dent near bottom bracket - alu frame
[#2921581]
So after a grand total of 5 rides, the new bike has a reasonable dent near the bottom bracket. No falls, so I can only assume it's a rock strike. It's about 2" away from the bottom bracket on the underside of the downtube. About 1" long, 1/2" wide and maybe 1mm deep, running along the tube rather than across it. It's on heli-tape, so the frame isn't punctured or scratched. Not near any welds either.
Are these things terminal, or is it a case of suck it and see and I'll still be riding it 6 years from now?
Posted : 07/07/2011 9:19 am
It's a standard feature of any bike that has been ridden. You'll be fine.
Posted : 07/07/2011 9:58 am
as long as it's a dent and not a crease you should be fine. Even the latter will probably be ok.
Just keep an eye out for paint cracking/visible metal and investigate further if you see it.
Posted : 07/07/2011 9:59 am
 JonR
Its dead. I'll give you a fiver for it.
Posted : 07/07/2011 11:31 am
You'd pay a fiver for a Pronghorn?
Mug 😆
Posted : 07/07/2011 11:45 am
 gazc
did that to my heckler about 5 years ago, got a few more to go with it now and it's still going strong. wouldn't worry about it but worth checking for cracks to keep peace of mind
Posted : 07/07/2011 11:47 am
Fair dos. I'll just keep an eye on it then.
Cheers.
Posted : 07/07/2011 11:55 am
Someone once told me that a dent on the downtube is not too much to worry about - because most of the stress on the tube is pulling it, the dent has little effect.
On the top tube is potentially more of a problem, as the stress is pushing inwards, thus increasing the likelihood of the tube creasing.
If that makes sense.
Posted : 07/07/2011 11:59 am
I've got 2 there + another in the BB shell. Don't know how I did that.
Posted : 07/07/2011 12:03 pm
 D0NK
check check and check, also got a ding on my etsx and had a bloody enormous dent on my inbred downtube, and seattube and some battered chainstays. All still fine....for now.
Posted : 07/07/2011 12:04 pm
Welcome to the club. I seem to be able to do this to any bike I own in the first or second ride. Must be the nature of big rocky decents in the Peaks I think. ANyway, I've never had a frame die because of it.
Posted : 07/07/2011 12:11 pm
my fuel ex has several beauties too - rides fine
Posted : 07/07/2011 1:03 pm
