Degreasing seat tub...
[Closed] Degreasing seat tubes
[#6856382]
I am just preparing to fit carbon seat posts to two bikes, one carbon and one aluminium (if it makes any difference). Obviously I will need to degrease the seat tubes beforehand.
As I see it, I could either use a meths soaked rag or a muc off soaked rag and clean them that way or, are both of these ideas fundamentally flawed? Or is there a standard procedure for this type of operation?
Posted : 12/02/2015 12:57 pm
I stuffed lots of newspaper down the seattube, being careful not to let it break apart when pulling it back out.
WIth hindsight, an old cloth would be better... I didn't use meths, and so far have not had a problem, but there wasn't much grease in there to start off with.
Posted : 12/02/2015 1:52 pm
Suspend the bikes upside-down and stuff a rag soaked in paraffin or meths up the tube, pushing part of it in with a stick or a wooden spoon but keeping hold of it! Remove stick, pull out the cloth and repeat then finish with a dry cloth.
Posted : 12/02/2015 1:58 pm
Any degreaser will do, IPA, washing up liquid, bike specific stuff etc ...
But this is only necessary if you have heavily greased your previous seatpost. I would just give it a good scrub with some paper tissue. I don't think a small amount of grease residue will effect it as long as you are using some anti seize compound or carbon assembly paste.
Posted : 12/02/2015 1:59 pm
Is it still wise to use grease on seat tube - I do otherwise it seizes or is there a better option I have missed?
Posted : 12/02/2015 10:13 pm
Take the BB out and spray IPA or meths down there. Then clean with a rag on a stick. Repeat till clean.
Removing the BB prevents all the mungdungus sitting at the bottom and you can clean it all out.
I keep my seatposts as clean as possible as otherwise the grease holds the dirt. Reverbs have a smear of anti seize near the clamp as they don't get constantly moved.
Posted : 12/02/2015 10:31 pm
Copper slip or anti seize on metal posts and frames. Carbon assembly compound on any carbon parts.
I used to use grease as a cheap alternative, it worked okish but the post would slip every now and then.
Posted : 13/02/2015 1:51 am
CF to alu could react and seize. You'll need to consider a CF assembly compound and frequent checks
Posted : 13/02/2015 8:09 am
Drop a chunk of cat food down your seat tube, marinade a ferret in Muc-off, and introduce it to the top.
Works every time.
Posted : 13/02/2015 8:20 am
Get an old rag (I usually use a bit of old T-shirt) and wrap it around a piece of wooden dowel. Soak the rag in isopropyl alcohol and use it to clean right down into the seat tube.
Posted : 13/02/2015 9:16 am
Works every time.
😆 superb.
Posted : 13/02/2015 9:29 am
